Author Topic: Found part on Digikey.... Altium can't find it!!  (Read 1808 times)
Offline Stupid BearTopic starter
« on: January 30, 2023, 05:08:49 am »
Found this part on Digikey...
https://www.digikey.com/en/products/detail/linear-integrated-systems-inc/SST201-SOT-23-3L-ROHS/14312266
But when I do a manufacturers part search it doesn't come up.  Can I manually insert it and create a link to Digikey like Altium does. I can manually add the properties but can I also add the link at the bottom with the datasheet button or is that just something that Altium does on its own?
Offline ahbushnell
Re: Found part on Digikey.... Altium can't find it!!
« Reply #1 on: January 30, 2023, 07:44:39 pm »
Create your schematic part which I assume you have done.  Then go to Manufacturer part search and put in the digikey part number and search.  From there you can down load the info.  I just tried it on one of the parts I created.
Offline ahbushnell
« Reply #2 on: January 30, 2023, 07:47:51 pm »
I just tried it with your part and nothing.  :<  There are three types of parts depending on the packaging.  I wonder if that has something to do with it.  I guess I would do it manually.  Or try mouser or something else.  Good luck
Andy
Offline Rachie5272
« Reply #3 on: May 26, 2023, 08:12:05 pm »
This happens to me regularly, even when I give altium the full digikey part number.  It's also infuriating how altium insists on "searching" with a digikey part number, and makes me dig through the results for the one I input in the first place.
