Author Topic: tented via cleverness, with testpoints.. thought I'd share  (Read 5848 times)
Offline dhTopic starter
« on: June 07, 2011, 01:08:39 am »
Messing around with tented vias, I came up with a decent solution to Shift-F, Select All Vias, Force Tenting and the like:
Using rules, you can make a SolderMaskExpansion rule like this:
SolderMaskExpansion
+SolderMaskExpansion_Via
SolderMaskExpansion is the default (5mil expansion), and SolderMaskExpansion_Via is
IsVia And (Not IsTestpoint)
Expansion = -5000mil
This tents all vias, but leaves testpoints clear!
