I would suggest using the octagonal pad style if you'd like to mimic this. Be sure to create an annular ring large enough so pad breakout isn't as big of a problem with drill misalignment.
The annular ring is the pad area that is remaining after drilling. A typical recommendation is to size the pad to be at least 80% larger than the hole. I'd have it even larger if I'm drilling by hand.
