Author Topic: Line coating only - Altium Designer  (Read 2967 times)
Offline tuan179Topic starter
  • Country: vn
« on: March 12, 2024, 05:56:51 am »
Recently I am looking for a way to make a pcb like the attached picture. If I did it manually I would probably need to create solder surface areas all over the circuit board blanks (except the lines and copper coating). I hope someone will show me a faster way. Thank you so much!
Offline thm_w
  • Non-expert
Re: Line coating only - Altium Designer
« Reply #1 on: March 12, 2024, 09:11:38 pm »
The following users thanked this post: tuan179
  • Country: vn
« Reply #2 on: March 14, 2024, 06:40:26 am »
thank you!
