Hello,
I printed my pcb and i got this:
http://marek.php5.sk/wp-content/uploads/2013/10/offset.pngYou can see that holes of U2 is shifted. Holes in right looks ok.
My workflow is:
-generate print preview
-set up colors, layers, scale...
-print with pdf printer
The colored print is also shifted. When i generate pdf with "output job file" offset is also there. U2 on image is MAX232 which i found in standard library "TI Interface Line Transceiver.IntLib". Holes in parts that i drawed myself are also shifted
...any advice is appreciated
