Author Topic: Altium DRC doesn't seem to catch via-to-metal spacing issues  (Read 2139 times)
Offline TheUnnamedNewbieTopic starter
  • mmwave RFIC/antenna designer
So, I have a pcb with only blind microvias. The metals on different layers have different thicknesses and as a result each of my micro-vias and metals has different pitch/diameter/spacing.
I 'fixed' this by having a separate clearance rule for each layer. The rule would be something like 'Where first object matches InLayer('M1') and second object matches InLayer('M1')' . This seems to work fine for 99% of my design - but it doest seem to catch a lot of via annular ring clearance issues. Even though my DRC is clean in altium, the manufacturer says there are a lot of DRC errors still remaining. EG the via below, which is too close to the metals on the left and right, clearly violates the DRC rules, yet the DRC results are clean for that metal layer.
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline thinkfat
    • Matthias' Hackerstübchen
Re: Altium DRC doesn't seem to catch via-to-metal spacing issues
« Reply #1 on: July 09, 2021, 08:03:34 am »
Rule might not trigger because the via and the second object are on the same net? Is there a 'same net' constraint you could use or formulate a manufacturing constraint and not an electrical rule?
« Reply #2 on: July 09, 2021, 10:11:25 am »
The via and surrounding copper is not the same net here, so that is not the issue
Offline voltsandjolts
« Reply #3 on: July 09, 2021, 11:16:18 am »
This is the age old game where the OP provides a bare minimum of information and then everyone else submits their guesses as to the problem.
How about providing a minimal PCBdoc that shows the problem?
Offline JohnG
« Reply #4 on: July 09, 2021, 06:30:28 pm »
The clearance between your via and the trace on that layer is not being checked by the specified clearance rule because the via is on the Multilayer, not on the individual internal signal layers like you have defined in your clearance rule.
I bet it's this. I got bitten by this, and it took a lot to figure this out, even with support from Altium.
Cheers,
John
"Reality is that which, when you quit believing in it, doesn't go away." Philip K. Dick (RIP).
