Author Topic: BGA footprint wizard doesn't allow me different vertical and horizontal pitch  (Read 416 times)
Offline TnFTopic starter
  • Country: cy
BGA footprint wizard doesn't allow different vertical and horizontal pitch (aka pad to pad distance), it resets the other box as soon as i click out to edit it, any fix?
Offline thm_w
  • Non-expert
I see the same thing. Can you use the IPC footprint wizard instead to create it?
The "Footprint Wizard" seems to be a bit simpler.
The following users thanked this post: T3sl4co1l
  • Country: cy
I've fixed them manually but it's definitely a bug. You can make any rectangular grid array with different x and y pitch, you can report it so they fix it if you want, i've tried the other wizard too but it doesn't support different pitch on each axis.
