Author Topic: Wanted: STEP/STL for 6.35mm 6pin phono pcb jack  (Read 2471 times)
Offline PsiTopic starter
« on: August 10, 2018, 09:10:18 am »
Does anyone have a step/stl for a 6.35mm 6pin switched phono jack?
Something like this.
https://www.taydaelectronics.com/6-35mm-1-4-stereo-insulated-switched-socket-jack-pcb.html
doesn't need to be identical just same sort of part with same footprint.
thanks
Offline D3f1ant
  • Doing as little as possible, but no less.
Re: Wanted: STEP/STL for 6.35mm 6pin phono pcb jack
« Reply #1 on: August 12, 2018, 02:33:16 am »
« Reply #2 on: August 12, 2018, 10:37:53 am »
Great,
Thanks.
is grabcad actually free. I had assumed it was going to ask for money after i went to the trouble of registering.
Offline tszaboo
« Reply #3 on: August 12, 2018, 10:40:43 am »
Great,
Thanks.
The other website worth looking for is 3dcontentcentral.
Offline mengfei
  • Country: ph
Offline D3f1ant
« Reply #5 on: August 14, 2018, 12:00:51 am »
Grabcad is free as well. Between 3Dcontentcentral and grabcad our 3D model requirements are fairly well covered. I don't know how the 'pay' sites stay in business. I still end up doing a few myself, guess should start uploading ;)
« Last Edit: August 14, 2018, 12:02:23 am by D3f1ant »
Offline mengfei
  • Country: ph
« Reply #6 on: August 14, 2018, 06:39:19 am »
I can't seem to find SOT-23-8 there, is it somewhere hidden?
Offline julianhigginson
« Reply #7 on: August 14, 2018, 01:40:52 pm »
this one looks like it has a configuration to sot-23-8
http://www.3dcontentcentral.com/download-model.aspx?catalogid=171&id=434046
