Hello, is there any way to enable pin moving (with drag n drop) on schematic sheet? I am not sure in which version but there was just a check box (Enable pin editing) and you could just do it...
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
The only way I found was with coordinates under Properties -> Pins -> Location
It is very handy on making good looking schematics without modifing libs.
Thank you
