I'm working on a design (excuse messy areas) and was curious as to what the final gerber outputs would look like. I went through Alitum 14's Gerber generator and viewed the top copper layer (.GTL) in CAMtastic. However I notice that it seems to have duplicated other component layers, such as top silkscreen, on this layer too! I noticed that this only occurred on layers built using the IPC compliant wizard tool. I've attached an example below.
Is this a simple rendering bug? I've noticed the viewer isn't terribly great. Or is this a 'real' problem?
Many thanks for your time help, I appreciate it very much.
