Author Topic: Altium Layer Stackup For Transmission Lines  (Read 7986 times)
Offline PsychedelicBreakfastTopic starter
« on: September 06, 2012, 04:21:42 pm »
I'm a bit puzzled by Altium's layer stackup. I emailed my PCB fab. (Gold Phoenix) about substrate height, copper height and the dielectric constant and I was told the following:
1.6mm 1oz
Top---------------------------------- 1oz
               PP  7628(0.17mm)
     L2---------------------------------- 1oz
             core  1.2mm
     L3---------------------------------- 1oz
              PP  7628(0.17mm)
Bottom--------------------------------1oz
       1.61mm+/-10%
So I set the top and bottom layer to 1.6mm and the prepregs to 0.17mm and the core to 1.2mm, as shown in the picture below:
But when I try to setup a width rule based on characteristic impedence, I get negative values for the width(!). What am I doing wrong?
Offline free_electron
    • SiliconValleyGarage
Re: Altium Layer Stackup For Transmission Lines
« Reply #1 on: September 06, 2012, 05:14:38 pm »
you got something else wrong ...
6.69+6.69+47.2 don't add up to 189 ...
so you got your copper thickness wrong...
Offline gxti
« Reply #2 on: September 06, 2012, 05:40:48 pm »
The copper thickness doesn't show up directly in that dialog, you have to double-click on each copper layer and verify that it is set to 1 oz (1.4 mils, 0.036mm)
« Reply #3 on: September 06, 2012, 05:41:25 pm »
Copper thickness as stated in the email is 1.6mm. I set that too, for both bottom and top layer. So 62.9 * 2 mil + 47.244 + 6.693*2 =  186.43. If you add in the gnd and vcc plane thickness, it adds upto 189. The email didn't state anything about the thickness of the gnd/vcc plane (and Gold Phoenix isn't being helpful now) so I left it as default.
« Reply #4 on: September 06, 2012, 05:46:17 pm »
1.6mm copper on the outer layers ? what kind of board is this ?
1.6 mm they mean the total board thickness.
that outer layer copper  is 1oz . i do't kno any pacb house that uses such thick copper on the outer layers... that'll be an trmendously expensive board..
« Reply #5 on: September 06, 2012, 05:49:40 pm »
You're right. When I set 1.4 mil as the thickness for all the layers, the width came out as about 10 mil for 50 Ohm Zo. I was confused by their figures because they quoted 1.6mm twice, once near the top layer and once near the bottom layer.
Sorry about all the confusion! I appreciate the help.
« Reply #6 on: September 06, 2012, 06:43:55 pm »
you got negative numbers becasue the aspect ratio changed... the trace would have been thicker than it was wide ... and that upsets the calcs...
