If you order components from Digi-Key, sometimes you get a little moisture detecting card in the packet that turns pink in the presence of moisture.
I have found that if this is placed in your filament dryer (I use a food dehydrator) then, even if some circles have turned pink, it will turn blue again and can be taped or glued to a filament roll to indicate if it has been kept somewhere too moist.
Obviously it will react far quicker than your filament, so it should not be trusted to indicate whether your filament has become waterlogged or dry, but it will indicate whether the environment it is in is too damp.
If you use moisture absorbing crystals, it will let you know if they have stopped working also.
Of course, a proper hygrometer will do a much more accurate job, but this is free, and can be used on a roll by roll basis, and uses no power.
Myself, I have a BME280 connected to an arduino that lights a small red LED when the moisture goes over 40% for 1/2 an hour and only noticed this because I was curious whether the card reverted to blue when drying out some filament.
Hope this helps someone
