Just a few days ago i finished my third 3D printer and wanted to test it out yet had no filament, until i remembered that i had some PLA from the grocery store.
I don't know what flavor of PLA it is but it's meant for 3D pens and was located in the toy section and comes in a pack of 3 different colours in 3m lenghts each, 9m in total.
3m of filament is enough for a small test so i decided to print a test cube to see if my settings are correct.
The print came in undersize, turns out i forgot that i have 16T pulleys, not 20T.
But the plastic was super weird. I decided to give it a squeeze with some pliers to see how tough it is and it immediately cracked apart.
AFAIK normally prints separate at the layers but in this case the cracks went every way and layer lines couldn't even be distinguished.
The surface at the crack looked like glass - completely smooth. I thought that maybe the plastic is just brittle but with a knife it cuts like butter.
Printed another test cube with some pink coloured filament and when pulling it off my glass bed it fractured the bottom of the print (and also pulled some glass off dang it).
The fracture caused the bottom to become opalescent, which i thought was really neat.
I'm very new to 3D printing still but i thought this was cool enough to share.
Ps: last 4 pics are the opalescent print from different angles.
