For some time, I have been looking at enclosing my Ender 5 for two reasons. First, I want to add an air filter since it sits in my office and cold weather is here, so opening the window becomes a problem. Second, I would like to try printing some other materials, such as ABS or polycarbonate. Enclosing the printer will help with the fumes and with maintaining a higher temperature.
I wanted to keep the electronics outside as much as possible, so putting the whole thing in a box made that harder. Also, my space is not infinite...
I tend to do these things in bits and pieces when I need a break from my job, so this is a slow project for me. That being said, here are some pics:
The sides are 5.5 mm plywood underlayment that I treated with borax for fire resistance, and the side shelves are 18 mm plywood attached to the left and right side. They extend 25 mm beyond the boundaries of the top moving rail. I have still to make a bottom and top. The bottom will be a sheet of the same plywood. The top will be a polycarbonate box that rests on the the top of the printer and on the side shelves.
I'm passing this along in case it is useful to anyone else with an Ender 5.
John
