Author Topic: Glue  (Read 4901 times)
Offline PlainNameTopic starter
  • Country: va
Glue
« on: September 14, 2021, 04:09:05 pm »
Bit of a long shot, perhaps...
When I first got my printer (a Flashforge Dreamer) I spent quite a lot of time and effort sorting out the issue of having parts stick to the bed. I tried tape, glues, special pads, etc. Eventually I found the solution that worked every time: UHU purple glue stick.
But now I've run out, and it seems the purple stuff hasn't been available for quite some time. So long that there are no sources at all any more. UHU do a blue glue stick which is supposed to be the same, but it isn't - things barely stick at all, and even a slight draught can move prints in progress. By contrast, with the purple stuff I have to wedge a sharp knife under the part and then lever it off.
Anyone know of anything as good as the purple stuff? Or even the source of a few sticks?
Offline Just_another_Dave
Re: Glue
« Reply #1 on: September 14, 2021, 05:00:39 pm »
Some people use cyanocrylate for that purpose, but in my case hair lacquer has always been enough. I also tried kapton tape once, but it didn’t work well
Additionally, activating brim or raft in your slicer might also help sometimes
  • Country: va
Re: Glue
« Reply #2 on: September 14, 2021, 05:10:04 pm »
Raft helps but is a pain to get rid of afterwards. Brim used to work but is no use at all now.
Cyanoacrylate sounds rather expensive and could be annoying in the case of accidents! Don't have hairspray but will brave the pharmacy and try some. I'll just say I need it for my beard.
Offline james_s
Re: Glue
« Reply #3 on: September 14, 2021, 05:31:13 pm »
Cyanoacrylate is cheap if you look in the right places. I buy Superglue at the dollar store, 2 bottles in a pack. It's the same stuff you can pay several times more elsewhere.
  • Country: va
Re: Glue
« Reply #4 on: September 14, 2021, 06:51:09 pm »
I'll keep an eye out, but the only stuff I've seen is in relatively small bottles which don't look like they would last long. Still, if the hairspray doesn't work I could well be more receptive!
Re: Glue
« Reply #5 on: September 14, 2021, 07:10:11 pm »
If you’re going to try with hair spray, remember to let it dry before using the printer to ensure that it is sticky. You can also apply more than one coat
  • Country: va
Re: Glue
« Reply #6 on: September 14, 2021, 08:17:54 pm »
Thanks, will do.
I am wondering what made the purple stuff so good at this. None of the various glue sticks I've tried since have been any use once dry, and the purple stuff did dry since it went white quite quickly. Didn't seem awfully sticky to the touch, but it wouldn't let go of the PLA once introduced. Maybe it just took longer to actually dry, and by that time the first layer was down.
Offline jpanhalt
Re: Glue
« Reply #7 on: September 14, 2021, 08:31:54 pm »
Perhaps a wild thought:
Maybe that glue stick was a PVA adhesive.  That can be reactivated with heat.  There are lots of PVA adhesives on the market, i.e, almost any "white glue."
Here's a discussion: https://www.finewoodworking.com/forum/reactivating-yellow-glue-with-an-iron  (NB: I didn't search very hard.  There are probably better references.)
EDIT: Could the thin layer of adhesive from your glue stick be removed (slowly) with water?  Unmodified (i.e., uncrosslinked) PVA adhesives are slow to dissolve, but are not stable to water.  You can also add water to PVA adhesives to get a nice think coat.
EDIT#2:  Rosin (like for soldering and violins) and shellac are soluble in ethanol, and once dry can be heat activated too.
« Last Edit: September 14, 2021, 08:44:15 pm by jpanhalt »
Offline james_s
Re: Glue
« Reply #8 on: September 14, 2021, 08:49:24 pm »
Maybe the manufacture would be willing to tell you what the purple stuff was? They may not be aware that their product had found the use you were using it for.
Offline jpanhalt
Re: Glue
« Reply #9 on: September 14, 2021, 09:01:52 pm »
My guess is that the TDS, SDS, or MSDS has/had that information, if the manufacturer is willing to share.  Otherwise it will be a proprietary secret.  In that case, it will be limited to relatively non-toxic stuff, like library paste or PVA.
Offline Whales
    • Halestrom
Re: Glue
« Reply #10 on: September 14, 2021, 09:40:50 pm »
Aside: I have been using masking tape on my glass bed of my super-cheap prusa clone $300 kit printer and it has been working really well across hundreds of prints.  There is a secret that makes the difference between it being perfect and useless: soap and water.
If there is any hand grease on the tape (eg from assembling the tape or rubbing the centre print area with fingers) then the prints do not stick.  A paper towel, a little bit of water and a drop of dish detergent work wonders.  If the bed is heated then you don't even have to wipe it off.  Alcohol does _not_ work anywhere as well as soap and water, that's what I used to use and it often required multiple cleaning cycles + frustration.
PLA @ bed 55degC: works perfectly, I only ever have bed detach if there is hand grease on there.  Cancel the print, peel old off, clean bed with soap+water and re-run; so far this has always worked with once cycle.
PETG @ bed 70degC: sticks so hard I often tear bits of the tape during removal.
EDIT: take these bed temps with a grain of salt, in my design the bed thermistor is not really reading the top surface of the glass (it's on the bottom of the PCB element instead).  My actual resulting bed temps are probably (?) lower.
Photos below show a variety of marks on my tape: small (very tall) repetitive part marks in the centre, scratches around the edges from z-height getting knocked, several little tears all over the place from removing PETG.  I have replaced the centre tape line recently, so it might look a bit neater than the rest in places.  "It used to be nice and flat" :P  luckily the tape is soft and extra forgiving.
« Last Edit: September 14, 2021, 09:57:33 pm by Whales »
  • Country: va
Re: Glue
« Reply #11 on: September 14, 2021, 11:03:04 pm »
Yes, but the stuff that doesn't work is similarly slow to wash off.
Now there's a thought! I'll see if I have the right stuff - got some liquid flux that is super-sticky and almost impossible to remove if you spill half of it over the bench.
I will try and find a contact, but I have to say I won't be holding my breath :)
Ah, I wondered about doing that and should give it a try. That will mean a bout of bed-levelling though, and it's pretty spot on at the moment.
I'm using a thin mirror (for flatness) and 50C for PLA seemed to work well, which is pretty close to your figure.
Offline Whales
    • Halestrom
Re: Glue
« Reply #12 on: September 14, 2021, 11:42:55 pm »
Could this be the purple glue stick?
https://s3-ap-southeast-2.amazonaws.com/wc-prod-pim/Asset_Documents/Gloo%20Glue%20Sticks%20Purple%20SDS.pdf
(also attached, in case that link ever goes away.  MSDS are generally publicly available documents in Aus anyway)
ie:
 - PVA glue
 - common soap
 - glycerin (probably to thicken it?)
 - coloured dye
 - water
« Last Edit: September 14, 2021, 11:46:05 pm by Whales »
  • Country: va
Re: Glue
« Reply #13 on: September 15, 2021, 09:43:02 am »
Thanks for looking! I doubt if it's the same thing. The one I am after is this:
https://www.fishpond.co.uk/Toys/Uhu-Glue-Stick-Purple-860ml-Saunders/9999660083438
I just tried a BIC purple for no other reason than that it might be the colouring:
https://www.amazon.co.uk/dp/B01N9B1QEA
Same uselessness as all the other sticks.
  • Country: va
Re: Glue
« Reply #14 on: September 15, 2021, 09:54:46 am »
Googling around I found this:
https://www.reddit.com/r/mildlyinteresting/comments/26fwcu/my_purple_glue_stick_wasnt_used_for_a_while_and/
The stick sweated, and I wonder if that's the reason it was withdrawn. So, anyway, you know how Googling goes and eventually I would up here:
https://all3dp.com/2/what-s-the-best-glue-stick-for-3d-printing/
Hmmm, Elmers. Clearly (ho ho) a USA thing but blow me if the link didn't take me to Amazon UK, whereupon I ordered this:
https://www.amazon.co.uk/dp/B08PCHSL7Y
Should be here before 10pm...
Offline Whales
    • Halestrom
Re: Glue
« Reply #15 on: September 15, 2021, 09:57:35 am »
I initially doubted it would be the colourant, but given that the MSDS I linked claimed that colourant could be a few % of the final composition I might be wrong.
Found as MSDS for UHU Color Glue Stic, but they are completely troll with the ingredients.
Offline jpanhalt
Re: Glue
« Reply #16 on: September 15, 2021, 10:27:46 am »
I didn't find Saunders SAU99601 (your link), but this link calls the UHU glue stic "purple" with a different product number, SAU99653:
https://www.usaofficemachines.com/sau99653-uhu-stic-permanent-purple-application-glue-stick-1-41-oz-stick-by-saunders-mfg-co-inc.html
That number brings up this safety sheet:
http://content.oppictures.com/Master_Images/Master_PDF_Files/SAU99653_MSDS.PDF
As expected it is useless, except in addition to phenolphthalein (dye --> clear), it lists polyvinylpyrrolidone ("povidone")(https://en.wikipedia.org/wiki/Polyvinylpyrrolidone), but doesn't give a composition range.
If one clicks on the glue stick link in the Wikipedia article, you get this: https://en.wikipedia.org/wiki/Glue_stick
Edit: Sorry, I took a long time referring to post #14 and didn't see the more recent posts.
« Last Edit: September 15, 2021, 10:31:52 am by jpanhalt »
  • Country: va
Re: Glue
« Reply #17 on: September 15, 2021, 10:58:09 am »
The USA Office Machines place apparently has stock (but shipping costs make it worth more than its weight in gold). Hmmm.
  • Country: va
Re: Glue
« Reply #18 on: September 15, 2021, 08:17:29 pm »
Not a success :(
A bit sticky but the test print warped and lifted an edge, and the whole thing came off quite easily.
The following users thanked this post: Whales
Offline jpanhalt
Re: Glue
« Reply #19 on: September 15, 2021, 09:01:14 pm »
That's research.
Have you tried PVA glue (white or yellow wood glue) or rosin alone?  Polyvinylpyrrolidone is really quite similar to PVA.  Shellac may bond a little to well.  It can be used to attach irregularly shaped objects to the faceplate on a jeweler's lathe, but I have used it on a 3" hobby lathe too.
« Last Edit: September 15, 2021, 09:04:18 pm by jpanhalt »
  • Country: va
Re: Glue
« Reply #20 on: September 16, 2021, 10:25:30 am »
Not yet. I thought I would work my way through the least messy first, hoping I don't get to the really messy solution. So hairspray next.
  • Country: va
Re: Glue
« Reply #21 on: September 16, 2021, 10:26:24 am »
Forgot to say earlier: that's a nice little setup you have there  :-+
Offline Whales
    • Halestrom
Re: Glue
« Reply #22 on: September 16, 2021, 10:40:16 am »
Thankyou :)  Screwing the shaped board to my bookshelf to fit it has been perfect.  It's now "ready to print" any time, rather than requiring me moving it, wiring it and re-levelling it every time some small printing takes my fancy.
This printer design has a fatal flaw in that the left and right steppers for the Z axis go out of sync if you apply outside force to the gantry (eg when changing filament).  Until I worked this out I was constantly recalibrating bed levelling to suit the crooked gantry.  Now instead I use two high-precision calibrated german manufactured length standards (read: two flat AAA batteries) to fix this problem:
1. Home
2. G0 Z40 (raise the gantry 40mm)
3. Place the two AAA's against each vertical threaded rod
4. G0 Z0 (lower the gantry until it crashes into the AAA's and skips several steps)
5. G0 Z10 (relieve pressure off the AAA's)
6. Remove AAA's
7. Home again.
Voila, everything is straight and reliable now.  I do not have to re-level the bed anymore (unless my dodgy Z-top wiggles, but then I wiggle it back).  I literally do a few prints, leave it for a few weeks, come back and print some more without having to worry about levelling (or buying auto-levelling devices).
When I printed directly onto the glass I had to change the Z-stop (or re-level) when changing between PLA temps and PETG temps.  I have not had to do this at all for a long time, I think a combination of a fatter first layer (0.35mm, even when doing the rest as finer layers) and the soft masking tape has helped me here.  Again, avoiding the fiddly stuff means I can just print whenever I want now :)
EDIT: Said length standards can be seen stuck to a magnet on the top-left of my printer in the earlier photo.
« Last Edit: September 16, 2021, 10:49:35 am by Whales »
  • Country: va
Re: Glue
« Reply #23 on: September 16, 2021, 11:45:53 pm »
The Dreamer is three-point manual adjustment, so a bit of a faff (although it's actually reasonably quick and simple).
Hairspray is a no. Not just because it didn't work but also because it stunk the office out.
So, on to masking tape which worked very well indeed! Didn't need to prise the model off at the end, but it didn't fall off either. If it works like this every time my search is completed  :-+
Just remains to see how long it will last before needing to be resurfaced.
Offline Whales
    • Halestrom
Re: Glue
« Reply #24 on: September 17, 2021, 07:59:14 am »
Never tried hairspray.  I didn't remember that the stuff stinks, thankyou for testing it for me  ;D
Recently someone suggested I make some skins over 3d printed frameworks using crepe paper and hairspray.  Might rethink that, try and find out what else I could use.
Glad you found something that works.  I've read claims that different brands/types work and others don't, but it might just come down to cleaning the human grease off vs not.  EDIT: I wonder if plain A4 paper works if you clip it down...
