Where do you come up with these oddball layer heights?
Were you referring to me?
If you mean the 0.3mm height, that's the default in my slicing software and what I've used. As for the 0.13mm height, I didn't remember if the suggestion was 0.12 or 0.13, but I didn't realize multiples of 0.04mm was important. Maybe I even used 0.12mm and thought I used 0.13mm. Again though, I didn't realize multiples of 0.04mm was important until now.
If you're asking about the two different tools, the 'revolution' is an additive action while the 'groove' is a subtraction action.
Yes, that's what I'm asking about. Let's say I wanted to make diagonals, not necessarily threads, just 45 degree angles all connected together. I could draw a horizontal line, go up 45 degrees to the left, 45 degrees to the right, etc... draw a line back to the z-axis, and down to the 0,0 point. Now perform a revolution and I have the same as I would with groove (or believe I would).
Using 'groove' is still an uphill battle for me due to not grasping the whole tree structure. I create a sketch, then a pad, then another sketch, etc... I can follow the 1-2-3 steps, but I don't grasp the whole concept.
