Author Topic: 3D Printer yet?  (Read 358182 times)
0 Members and 14 Guests are viewing this topic.
Offline Brumby
Re: 3D Printer yet?
« Reply #1725 on: December 02, 2020, 06:00:06 am »
Sorry if I came across as dismissive to any safety related matters.  I am anything but.
The role of devils advocate is often an essential one - and that's in addition to offering aid based on experience.  I would consider withholding any advice on safety as negligence and culpability if anything were to go sour.
As for the extension of the concept to a cease and desist order ... that was meant purely as fun (in a sideways dig at our resident dwagon.)
« Last Edit: December 02, 2020, 06:02:24 am by Brumby »
Re: 3D Printer yet?
« Reply #1726 on: December 02, 2020, 04:01:55 pm »
And it was taken exactly that way... don't worry. The dwagon's hide is thick; he can handle a little poking. ;)
As for the Devil... he kicked me out for trying to take the place over.  >:D
Lawyers can be tolerated... I prefer mine ground to a fine paste. Then applied directly to the buttocks.
« Last Edit: December 02, 2020, 04:05:27 pm by mnementh »
Offline Brumby
Re: 3D Printer yet?
« Reply #1727 on: December 03, 2020, 11:06:53 am »
Yep....  That's the path I was heading down.   ;D
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1728 on: December 03, 2020, 08:34:32 pm »
Today is the day.
Today we will rejoyce togheter.
We won the battle.
We did it.
8 888888888o.      8 8888      88        .8.          8 8888                    8888888888',8888'
8 8888    `^888.   8 8888      88       .888.         8 8888                           ,8',8888'
8 8888        `88. 8 8888      88      :88888.        8 8888                          ,8',8888'
8 8888         `88 8 8888      88     . `88888.       8 8888                         ,8',8888'
8 8888          88 8 8888      88    .8. `88888.      8 8888                        ,8',8888'
8 8888          88 8 8888      88   .8`8. `88888.     8 8888                       ,8',8888'
8 8888         ,88 8 8888      88  .8' `8. `88888.    8 8888                      ,8',8888'
8 8888        ,88' ` 8888     ,8P .8'   `8. `88888.   8 8888                     ,8',8888'
8 8888    ,o88P'     8888   ,d8P .888888888. `88888.  8 8888                    ,8',8888'
8 888888888P'         `Y88888P' .8'       `8. `88888. 8 888888888888           ,8',8888888888888
I can't believe that CNC plate was just perfect,
I love my Mitutoyo even more than before..... I need to buy another one.
Print size stock: 220x220x300
Print size now: 230x230x320.
... and when I say nothing wobbles, I mean
« Last Edit: December 04, 2020, 08:49:11 am by Zucca »
Re: 3D Printer yet?
« Reply #1729 on: December 03, 2020, 09:36:46 pm »
I thought you were going with a 3-stepper arrangement...? :o
That price included the plate? Looks like 4-5mm thick... ~US$83... pretty reasonable considering the work involved. Hydro-cut? Did you tap the threads yourself?
 :-/O
« Last Edit: December 03, 2020, 10:21:22 pm by mnementh »
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1730 on: December 04, 2020, 08:59:34 am »
If you have a Fiat 500 you can't turn it in a Ferrari, the best you can do is
68 Euro just the plate, total upgrade cost was about 100€.... I believe was laser cutter and normal CNC stuff...
No, I did not cut the threads myself.
« Last Edit: December 04, 2020, 09:01:51 am by Zucca »
Re: 3D Printer yet?
« Reply #1731 on: December 04, 2020, 03:52:45 pm »
 :-DD Understood.
I meant did the ~US$83 include material, or was that just the labor. If he threaded the holes too, then def a good deal; usually as much time in that as the rest of the job put together.  :-+   Especially if a tap breaks, which is not uncommon with aluminum plate. :palm:
As for 3-steppers... I thought your plan was to have on the front one slider/rail in the center, two leadscrews at the corners, not t'other way around. That's also why I strongly suggested a sync belt. ;)
 :popcorn:
« Last Edit: December 04, 2020, 04:03:36 pm by mnementh »
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1732 on: December 05, 2020, 07:20:08 pm »
Regarding the Marlin bed leveling, I found this video on UBL very interesting:
I will try now the UBL manual on 4x4.
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1733 on: December 05, 2020, 08:44:15 pm »
Done with cold bed
Send: G29 T
Recv:
Recv: Bed Topography Report:
Recv:
Recv:     (  1,229)              (229,229)
Recv:         0       1       2       3
Recv:  3 | +0.015  -0.020  -0.020  +0.050
Recv:    |
Recv:  2 | -0.055  -0.105  -0.120  -0.045
Recv:    |
Recv:  1 | -0.070  -0.105  -0.115  -0.045
Recv:    |
Recv:  0 |[+0.025] -0.010  -0.005  +0.070
Recv:         0       1       2       3
Recv:     (  1,  1)              (229,  1)
Recv:
Recv: ok
UBL FTW!
Re: 3D Printer yet?
« Reply #1734 on: December 06, 2020, 07:10:44 pm »
*pokes xrunner's avatar with a stick*
boo!
 :popcorn:
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1735 on: December 06, 2020, 07:21:29 pm »
Okay I am now 100% UBL 5x5 with no probe! I will never go back, it is fantastic!
The documentation on Marlin for an UBL with manual probing is not the best, bur with a little bit of patience I managed to get it up and running.
Problem you need a board that can handle >256KB of juice.
On other news:
I am now using the old magnet bed as a mouse pad.
I never felt a mouse flying under my hand like now! Why I did not put it under my mouse immediately after installing the glass bed?
whoooosh...
Re: 3D Printer yet?
« Reply #1736 on: December 08, 2020, 03:13:45 am »
CR-6 auto-leveling just plain works. Even my Diggro is pretty close to zero assache since I replaced the crunky rollers on the Y-axis. :-//
 :popcorn:
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1737 on: December 08, 2020, 10:10:03 am »
Mine worked too, I just wanted to test the next level... UBL!
Is the CR-6 the one with a load cell? Oh yes it is.....
The idea is nice... but I think it is overkilling.... A shim gauge set will be my next toys for allignment, and then I call it done for ever.
« Last Edit: December 08, 2020, 10:13:52 am by Zucca »
Re: 3D Printer yet?
« Reply #1738 on: December 08, 2020, 04:09:45 pm »
Naahhh... there are just too effing many variables involved in using measured current from a leadscrew/motor(s) as a bed sensor; too many places where a change in the inherent loading/friction of the setup can create an inaccurate reading, ultimately leading to a smashed glass or damaged polymer print surface. The engineer in me just shrieks at the idea of having the measurement device be part of the motor device; it's like having a PID loop programmed so the changing weight of the PID loop itself affects the self-calibration of the PID loop.
Enjoy at your own peril, he says. ;)   The load cell in the hotend is the obvious choice, and it is so cheap. You can build the whole thing, bespoke design hotend and all for ~US$30. Only weakness is I dunno if it can handle the added weight of a DD extruder; that of course would be a matter of empirical design.  :-//
"Good night, and may your god go with you."
« Last Edit: December 08, 2020, 04:22:20 pm by mnementh »
Re: 3D Printer yet?
« Reply #1739 on: December 08, 2020, 06:32:40 pm »
This will be the back leg for a 10" digital photo frame I picked up at the Thrift. :-+
Getting better at Frustion360; I had a clear plan of how to make this from the start, including optimizing the design for flat printing. Total design time ~45 minutes. Currently printing at 0.20 LH, 40% Infill, Concentric pattern, 1.5mm wall/top/bottom thickness. We'll see how it works out; this is the first iteration based on my best guesses & rough measurements.
I prepared Explosive Runes this morning.
« Last Edit: December 08, 2020, 06:35:27 pm by mnementh »
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1740 on: December 08, 2020, 10:40:04 pm »
I would like to see how much patience you will loose with FreeCAD. Personally if I can't save the project on my HDD... I go  :scared:
UUhhh "concentric pattern" I need to try that, did you choose it because that thing need to flex?
Re: 3D Printer yet?
« Reply #1741 on: December 09, 2020, 04:24:38 am »
I chose concentric for cosmetics and for the fact it builds the deposition mostly in the longitudinal direction, which makes it strongest in the correct plane.
This is the promise of home 3DP fulfilled; a few minutes designing, set the machine to work and go on aboot your business. Come back in a few hours and you have a complete, ready to use part waiting to be popped off the bed and put to use.
And now a digital picture frame that was destined to become eWaste becomes an extra Xmas prezzie to mom-in-law; one we know she'll love as it comes loaded with pics of us she hasn't seen. :-+
 :popcorn:
« Last Edit: December 09, 2020, 04:26:19 am by mnementh »
The following users thanked this post: CatalinaWOW
Offline CatalinaWOW
Re: 3D Printer yet?
« Reply #1742 on: December 09, 2020, 04:35:47 am »
Totally agree.  Action figures and Millenium Falcon models are fun, but the real benefit for 3D printing for people with some technical skills is making repair parts, making custom devices and the like with low input of personal time.  Telling the robot to go fabricate is far more appealing than a day of milling, filing, drilling and otherwise shaping.  And there is a lot of satisfaction out of recovering a previously unusable object.  Battery compartment covers alone are worth it, even though they are usually fairly challenging to 3D print.
Re: 3D Printer yet?
« Reply #1743 on: December 17, 2020, 06:40:20 am »
No comment...  >:D   https://www.thingiverse.com/thing:4589796
*toddles off to ded*    :=\
Offline Mr.B
Re: 3D Printer yet?
« Reply #1744 on: December 17, 2020, 07:24:44 am »
...but the real benefit for 3D printing for people with some technical skills is making repair parts, making custom devices and the like with low input of personal time.
This!
The majority of my 3dp projects are practical, replacements for broken parts, specialist parts or adapters that you cannot just buy, or improvements on existing designs.
I hope that is *Bed* and not *ded*...   ;)
Offline tautech
Re: 3D Printer yet?
« Reply #1745 on: December 17, 2020, 08:14:41 am »
This!
You are aware of this thread are you ?
https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/
Ded as in out to it in bed. Yep just mnem saying he's had enough for the day and if truth be known after an evening tipple I'll be right behind him.  :phew:
Most of the day at the lathe was damn tiring work !  :=\
Some stuff seen @ HQ cannot be shared.
Offline Mr.B
Re: 3D Printer yet?
« Reply #1746 on: December 17, 2020, 08:29:52 am »
Semantics of language.
I get it...
*Dead to the world* in your bed...
Re: 3D Printer yet?
« Reply #1747 on: December 18, 2020, 04:02:57 am »
Yup. I put the last dash on DP just before 2AM. I was beyond dead on my feet; all I wanted to be was dead to the world in bed. :-+
Re: 3D Printer yet?
« Reply #1748 on: December 20, 2020, 11:37:19 pm »
Boring mundane household object print number 137: Hooks to hang my headphonezz up.
*yawwnnnn*
« Last Edit: December 21, 2020, 04:23:29 am by mnementh »
Re: 3D Printer yet?
« Reply #1749 on: December 21, 2020, 03:13:17 pm »
https://www.thingiverse.com/thing:4679704
 :-DD
https://www.thingiverse.com/thing:4670812
Gallows humor; Please don't jump my shit. Even tho I probably deserve it. ;)
« Last Edit: December 21, 2020, 06:09:10 pm by mnementh »
