Just updated the screen FW again this morning. Like I said, they make changes to it all the time, which I suppose is better than them not caring any more.
This time I noticed an error that has appeared during the upgrade process for several upgrade cycles, regarding some mis-match of a .bmp file, has also been fixed.
The only things I change in the config.ini file are these - however there are other things you
could play around with. Remember - nothing can go wrong,
#### Auto Save Load Leveling Data
# The TFT will auto-detect if Auto Bed Level is available.
# Enable this will send "M500" after "G29" to store leveling value
# and send "M420 S1" to enable leveling state after startup
# Options: [enable: 1, disable: 0]
auto_load_leveling:0^^^ I changed it to 0
#### Persistent temperature info
# show persistent temperature info on all menu screens
persistent_info:1^^^ I changed it to 1
#### Default Marlin Mode Background & Font Color Options
# Options: [ WHITE: 0, BLACK: 1, RED: 2, GREEN: 3, BLUE: 4, CYAN: 5, MAGENTA: 6, YELLOW: 7,
# ORANGE: 8, PURPLE: 9, LIME: 10, BROWN: 11, DARKBLUE: 12, DARKGREEN: 13, GRAY: 14, DARKGRAY: 15]
# Or set the color(RGB888 format) hex value directly(start with “0x”).
# Such as: 0xFF0000 : Red, 0x00FF00 : Green, 0x0000FF : Blue
marlin_bg_color:1
marlin_fn_color:7^^^ I changed it to 7
