Author Topic: 3D Printer yet?  (Read 351026 times)
Re: 3D Printer yet?
« Reply #1600 on: November 11, 2020, 04:15:09 pm »
This pleases me.
« Last Edit: November 11, 2020, 04:16:56 pm by mnementh »
Re: 3D Printer yet?
« Reply #1601 on: November 11, 2020, 07:12:19 pm »
   Oooohhhh... shinyyyyy....   Cura 4.8 is out, at the usual location: https://ultimaker.com/software/ultimaker-cura
It finally has a printer profile for CR-6SE, instead of having to flerp my own from the crunky old version of Cura that CReality molested for fun & profit. :palm:
Look at all these delicious print profiles... and those just for 0.40 nozzle!
*lunchtime*
Re: 3D Printer yet?
« Reply #1602 on: November 11, 2020, 07:52:39 pm »
Currently printing at .016LH and ~40mm tall.  >:D
So wrong. ;D
« Last Edit: November 11, 2020, 07:59:27 pm by mnementh »
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1603 on: November 11, 2020, 09:18:02 pm »
I am finishing designing the dual Z on my ender 5.
I have to CNC a 369x210x4 mm aluminuim plate.
Once it is done I will catch you at .016LH mnem...
Re: 3D Printer yet?
« Reply #1604 on: November 11, 2020, 10:01:07 pm »
Then we can both try 0.12.  >:D
I think 0.10 is possible, but maybe not with the microsteps on 8mm pitch leadscrew. I'd have to do the math; might have to drop down to 0.08mm, not likely possible.
Then too, the CR-6SE is a native mesh-leveling design with fixed bed height and belt-synchronized Dual-Z, so maybe we CAN get that much precision out of a V-Slot design, if we're ready to run it slow enough... :-//
You mean nobody has a Dual-Z kit out for that model yet...? It's been out a while, hasn't it?
 :popcorn:
Re: 3D Printer yet?
« Reply #1605 on: November 12, 2020, 12:16:11 am »
wowzers.
 :o
Re: 3D Printer yet?
« Reply #1606 on: November 12, 2020, 12:37:37 am »
"Tree Everywhere" support. Interesting.... like he's been sealed in Carbonite. Have to cut the shell away a little bit at a time; like peeling a grape.
One last snip and he's free... just in time for family night.  ;D
EDIT: Here... have another. :-DD
« Last Edit: November 13, 2020, 01:20:28 am by mnementh »
The following users thanked this post: HobGoblyn
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1607 on: November 12, 2020, 07:26:00 am »
I googled it, all what I saw was chinesium or a solution that reduce the XY area.
So I decided to DIY.
« Last Edit: November 12, 2020, 09:30:29 am by Zucca »
Re: 3D Printer yet?
« Reply #1608 on: November 12, 2020, 03:41:28 pm »
Well, in their defense, it is a Chinesium 3DP so... I mean, stamped-aluminum-plate level of precision should be all that's required...  :o
 :-/O
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1609 on: November 13, 2020, 06:31:36 pm »
So, rnd Zucking department just called me. They are done with the plate for dual Z upgrade
it will be installed where the stock one is (you should filp the above plate left-right, oh well)
note the second Z will be outside the 2020 alu cube structure, so I will get the full 230x230mm XY area...
I give you all 48 hours to review my design before I go in production on Monday.
 8) 8) 8) 8)  :bullshit:
oh, another call from Zucking EE department, the new touchy touch me display and 32 bit board are here
It will be a fun weekend....  :-/O
« Last Edit: November 13, 2020, 06:36:48 pm by Zucca »
Re: 3D Printer yet?
« Reply #1610 on: November 14, 2020, 04:05:40 am »
They are going to be belt-synchronized, correct...?
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1611 on: November 14, 2020, 07:58:18 am »
No, no synch belt.
Improved design
the one before had weak point/axes exact where the higher flex will be.
I fired the rnd mechanical chief.
EDIT: see tech draw in attachment
« Last Edit: December 06, 2020, 07:49:16 pm by Zucca »
Re: 3D Printer yet?
« Reply #1612 on: November 14, 2020, 02:28:40 pm »
   No, no synch belt...
eeewwww.
and a half.
Offline Monkeh
Re: 3D Printer yet?
« Reply #1613 on: November 14, 2020, 02:31:42 pm »
Independent drive and leveling > sync belt. You do need three, though.
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1614 on: November 14, 2020, 03:24:53 pm »
I tend to agree
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1615 on: November 15, 2020, 10:05:55 am »
I am blown away...
schematics, manual, top and bottom layer everything is super well documented and available here
BIGTREETECH finally someone in china is swimming upstream!
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1616 on: November 15, 2020, 12:02:10 pm »
The upgrade has begun
Very glad that inspired by this I used 3mm L alu profile to mount the electronic in the back of the Ender5.
Unwanted safety feature: you can't remove the elec box panel without removing the main plug  first :-+
Re: 3D Printer yet?
« Reply #1617 on: November 15, 2020, 03:38:21 pm »
I tend to agree
With 2mm pitch leadscrew, I'd agree. With the usual 8mm pitch, just one more assache to keep retuning over and over and over again. |O
 :popcorn:
Offline Monkeh
Re: 3D Printer yet?
« Reply #1618 on: November 15, 2020, 04:23:12 pm »
I tend to agree
 :popcorn:
There's no assache, it just does it. And if you don't turn the steppers off, it only has to do it once.
Offline Nominal Animal
Re: 3D Printer yet?
« Reply #1619 on: November 15, 2020, 05:10:19 pm »
I am blown away...
You know, I think having v1.3 be a variant of the OSHW SmoothieBoard made them realize it is a good way to do this business.  (Make no mistake, SmoothieWare has always explicitly encouraged others to do this; this is a positive thing for all involved.  Props to Arthur Wolf!)
Offline xrunner
  • hp>Agilent>Keysight>???
Re: 3D Printer yet?
« Reply #1620 on: November 16, 2020, 01:53:03 pm »
Printed parts for a scrap yard office for N scale railroad. Came out great.
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1621 on: November 16, 2020, 02:06:51 pm »
why don't you install a 0.2mm nozzle?
Nice stuff btw.
Offline xrunner
Re: 3D Printer yet?
« Reply #1622 on: November 16, 2020, 02:33:24 pm »
Nice stuff btw.
I have one and I have tried it for some very (ridiculously) small items to see what would happen. A guy had designed a VW engine (the old air-cooled one) in 1:160 scale and wanted me to see if it would come out OK on my 3D printer. I said Hell No not with a 0.4 mm nozzle. I printed it to show him and it was basically a little blob of goo, but I bought a 0.2 mm just to see. It sort of kind of looked like the CAD mode - but it's not that obvious. It' just not worth it for what I'm printing out.
You know what "weathering" is right? Making perfect things look beaten and worn like the real world. It seems counter-intuitive at first, but it's actually not always good to have perfect things printed out, at least for what I'm making for this model railroad. The fact that models have small defects when 3D printed is sometimes a good thing.  :o
Offline SilverSolder
Re: 3D Printer yet?
« Reply #1623 on: November 16, 2020, 03:00:05 pm »
[...]  The fact that models have small defects when 3D printed is sometimes a good thing.  :o
Nothing's so bad it ain't good for something!
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1624 on: November 16, 2020, 03:06:43 pm »
xrunner once I have taken all the chinesium parts out from my ender 5, I will sell everything to you.
Very messy, realistic old looking, imprecise, and fuzzy 3D print results guaranteed.
