Author Topic: 3D Printer yet?  (Read 358051 times)
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1475 on: October 13, 2020, 07:43:28 pm »
For the Marlin experts  8)
are there two files
Configuration.h
Configuration_adv.h
structurally always the same in the 2.xxx marlin versions?
Example: upgrading from version 2.061 to 2.071 can I just overwrite the two ones provided from the remote branch in github?
In other words I want to upgrade the Marlin FW not my printer settings...
Many thanks in advance.
Online xrunner
  • hp>Agilent>Keysight>???
Re: 3D Printer yet?
« Reply #1476 on: October 13, 2020, 09:17:11 pm »
They aren't necessarily the exact same file each time. Sometimes they add definitions for the latest version for new features, and so if you compile it may not succeed.
Also there is a check in the file to prevent you from trying to do that. You can change it as I did once and it might compile (it did for me), but it might not like it either.
From configuration.h Marlin version 2.0.5.3 -
#define CONFIGURATION_H_VERSION 020005
and from configuration.h Marlin version 2.0.6.1 -
#define CONFIGURATION_H_VERSION 020006
I always now just compare the files and transfer my settings into the other file, leaving the new parts they put in there alone.
Re: 3D Printer yet?
« Reply #1477 on: October 14, 2020, 12:55:53 am »
So... went back to OEM, aside from the dual-drive extruder. We'll see...
*punt*
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1478 on: October 14, 2020, 05:05:42 am »
Thx.
Now the next question is why git merge does not do his job properly? When I merge my local branch with the new one from github my .h config are wiped out without even asking.
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1479 on: October 14, 2020, 05:06:23 am »
Your story make me worried to upgrade to mosquito.
Online Monkeh
Re: 3D Printer yet?
« Reply #1480 on: October 14, 2020, 03:15:30 pm »
Thx.
Did you have an actual branch with commits, or just a dirty tree?
Re: 3D Printer yet?
« Reply #1481 on: October 14, 2020, 08:11:19 pm »
So... after going back to stock, putting everything exactly the same as the last time it worked right... it STILL kept because FUCK YOU mnem!!!
Tried a different fan... still . I tried relocating the fan so it blew less on the nozzle... I tried a third roll of filament...
So I went back through all the pics in here from when it was printing awesome... and I finally realized what was different.
This little bastard stainless steel nozzle(s). I'd swapped one in thinking my original brass one was clogged. When I rebuilt with the MicroSwiss, I put this nozzle on it because it was one of the ones that came with it. So I reinstalled my old brass nozzle, did a cold pull to clean it (you can see it came nicely clean above), and...
BAM...! Got this result at 210° without even re-cal-ing my E-STEPS.  ::)
Jeezus H Christ a-hoppin on a pogo stick... what a clusterfuck.
Now... do I just enjoy the damn thing, or go to the hassle of rebuilding it with the 'fang again...? :o
Mmmmhmmm.... I have oodles of parts I wanna make right now. I think I'll tempt fate another time, when I'm not trying to get something else done...
"Sufficient unto the day is the evil thereof."  ~grand-momma
« Last Edit: October 14, 2020, 08:16:29 pm by mnementh »
The following users thanked this post: xrunner, HobGoblyn
Re: 3D Printer yet?
« Reply #1482 on: October 14, 2020, 09:13:30 pm »
Please everyone... a little prayer for my sanity...
Online xrunner
Re: 3D Printer yet?
« Reply #1483 on: October 14, 2020, 09:32:18 pm »
I was going to suggest a nozzle issue the other day but I figured it would insult your intelligence and that you'd already checked it out.  :-//
Glad you found it though.
Offline SilverSolder
Re: 3D Printer yet?
« Reply #1484 on: October 14, 2020, 10:02:21 pm »
That's interesting.  S/S is a lot worse heat conductor than brass -  probably the problem?
Re: 3D Printer yet?
« Reply #1485 on: October 14, 2020, 10:46:44 pm »
I dunno. Seems to me if it sucked that hard, why would anybody ever make a nozzle out of it? Also; a awful lot of SS cookware out there.
Much more likely a user error of some sort; either doesn't belong in this application or I didn't build the hotend right for that nozzle.  :-//
 :palm:
« Last Edit: October 14, 2020, 10:50:08 pm by mnementh »
Re: 3D Printer yet?
« Reply #1486 on: October 14, 2020, 10:50:27 pm »
Nooooooooooo!
This thing has been for a week now... but at least this is a different kind of kicking. Maybe I have some small measure of hope here... LOL
 |O
Re: 3D Printer yet?
« Reply #1487 on: October 15, 2020, 04:41:19 am »
Wouldn't have helped a damned bit. I'd have just put another new SS nozzle on there... in fact I did... and still been clueless.  :-DD
And you can't insult my intelligence; I know I know barely enough to guess at how little I know.  :o
Fuck, I'm lucky if I can tie my shoes without getting lost on the way back up.  :-DD
« Last Edit: October 15, 2020, 04:45:37 am by mnementh »
Re: 3D Printer yet?
« Reply #1488 on: October 15, 2020, 04:45:06 am »
[01:21]  [19%].
say no more.
Online Monkeh
Re: 3D Printer yet?
« Reply #1489 on: October 15, 2020, 04:46:45 am »
Steel nozzles do need higher temperatures and even more care with cooling fans, and can be troublesome. Generally if you're only printing plain PLA, PETG, and styrenes (ABS, ASA, HIPS..), bare brass is easiest. So far I've stuck to brass and not used stainless, hardened, or plated nozzles and been happy.
« Last Edit: October 15, 2020, 04:49:01 am by Monkeh »
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1490 on: October 15, 2020, 06:46:33 am »
Thx.
I got local the Marlin 2061 and set up a git local branch with a few commits. Then I tried to merge the remote Marlin 2.xxx with my local branch and puffff all the .h blowing in the wind (like the answer my friend is blowing in the wind  :-DD).
« Last Edit: October 15, 2020, 06:56:32 am by Zucca »
Offline Zucca
  • EE meid in Itali
Re: 3D Printer yet?
« Reply #1491 on: October 15, 2020, 06:56:05 am »
My take away: 3D Printing is always a patience game, part of the much bigger Humans vs Machines war.
Machines win only if we give up.
Re: 3D Printer yet?
« Reply #1492 on: October 15, 2020, 03:02:15 pm »
One thing my recent 1st layer adhesion issues have actually been a boon with: Yesterday I got through 4 iterations of the design because it printed just enough of the part to allow some test-fitting before coming off the bed. Currently on rev4.1...
 :P
Re: 3D Printer yet?
« Reply #1493 on: October 16, 2020, 03:08:53 am »
Some progress... and ~$1.50 worth of filament wasted. A clone build-tak that came with a spool of filament resolved my adhesion issues, as well as giving a nice sandstone finish to the front of the piece. However, after successfully printing a nosepiece, I found it had a couple fitment errors that required some severe modification to the design. While I beat Frustion360 into submission, I set the printer to work on another tailpiece.
In the morning, I'll see how my new design behaves.
If only I'd noticed that my design was ~8mm too short to fit while I had all those truncated bits in my hand...
Re: 3D Printer yet?
« Reply #1494 on: October 16, 2020, 02:26:32 pm »
It sure is nice when the iterative part of Iterative Design actually works.  :-DD
While trimming up this tailpiece, I was struck with an idea for an all-new design which might actually do some muffler-ey action. Currently printing up a new nosepiece; now on Rev5.1.
« Last Edit: October 16, 2020, 02:34:07 pm by mnementh »
Re: 3D Printer yet?
« Reply #1495 on: October 16, 2020, 03:06:11 pm »
You realize you could have probably carved that part out of alabaster with a knife, by now?  :D
Re: 3D Printer yet?
« Reply #1496 on: October 16, 2020, 04:53:13 pm »
Not 6 copies of 2 pieces (plus a dozen revisions) I couldn't.  ;)
 :popcorn:
Re: 3D Printer yet?
« Reply #1497 on: October 17, 2020, 03:37:00 am »
Sound level is noticeably decreased with both endpieces... but I am still working on a new tailpiece design which is more similar in style to the nosepiece. Hopefully it will also be a bit mo quiet-ahh.
 :bullshit:
Online xrunner
Re: 3D Printer yet?
« Reply #1498 on: October 17, 2020, 12:51:19 pm »
So for an exciting start to the day, I downloaded and compiled Marlin 2.0.7.2 (yesterday the available file was 2.0.7.1). I did a compare between my configs for 2.0.6.1 and the new versions. I changed the appropriate parameters from my previous configs. I performed a mesh bed levelling, did a couple of test prints, and all was well.
There were not a whole lot of differences this time, but always a few. For example (if anyone is interested) they changed the PID portion a little bit as you can see below. In the new file they show an example of a list of PID parameters if you are using more than one hotend, and removed several different settings for some printer models. In the new file there is simply the PID parameters for the printer you are using (whatever it is). The PID parameters you see are for my Creality Ender-3 printer from running a PID tune, not the ones that came with the file.  :)
OLD (2.0.6.1)
#if ENABLED(PIDTEMP)
  #define PID_EDIT_MENU         // Add PID editing to the "Advanced Settings" menu. (~700 bytes of PROGMEM)
  #define PID_AUTOTUNE_MENU     // Add PID auto-tuning to the "Advanced Settings" menu. (~250 bytes of PROGMEM)
  //#define PID_PARAMS_PER_HOTEND // Uses separate PID parameters for each extruder (useful for mismatched extruders)
                                  // Set/get with gcode: M301 E[extruder number, 0-2]
  // If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it
// Creality Ender-3
  #define DEFAULT_Kp 23.75
  #define DEFAULT_Ki 1.76
  #define DEFAULT_Kd 79.96
  // Ultimaker
  //#define DEFAULT_Kp 22.2
  //#define DEFAULT_Ki 1.08
  //#define DEFAULT_Kd 114
  // MakerGear
  //#define DEFAULT_Kp 7.0
  //#define DEFAULT_Ki 0.1
  //#define DEFAULT_Kd 12
  // Mendel Parts V9 on 12V
  //#define DEFAULT_Kp 63.0
  //#define DEFAULT_Ki 2.25
  //#define DEFAULT_Kd 440
#endif // PIDTEMP
NEW (2.0.7.2)
  #if ENABLED(PID_PARAMS_PER_HOTEND)
    // Specify between 1 and HOTENDS values per array.
    // If fewer than EXTRUDER values are provided, the last element will be repeated.
    #define DEFAULT_Kp_LIST {  22.20,  22.20 }
    #define DEFAULT_Ki_LIST {   1.08,   1.08 }
    #define DEFAULT_Kd_LIST { 114.00, 114.00 }
  #else
  #endif
The following users thanked this post: Zucca, HobGoblyn
Re: 3D Printer yet?
« Reply #1499 on: October 17, 2020, 01:10:42 pm »
My balls still ache.:-DD
that is all.
