So for an exciting start to the day, I downloaded and compiled Marlin 2.0.7.2 (yesterday the available file was 2.0.7.1). I did a compare between my configs for 2.0.6.1 and the new versions. I changed the appropriate parameters from my previous configs. I performed a mesh bed levelling, did a couple of test prints, and all was well.
There were not a whole lot of differences this time, but always a few. For example (if anyone is interested) they changed the PID portion a little bit as you can see below. In the new file they show an example of a list of PID parameters if you are using more than one hotend, and removed several different settings for some printer models. In the new file there is simply the PID parameters for the printer you are using (whatever it is). The PID parameters you see are for my Creality Ender-3 printer from running a PID tune, not the ones that came with the file.
OLD (2.0.6.1)#if ENABLED(PIDTEMP)
#define PID_EDIT_MENU // Add PID editing to the "Advanced Settings" menu. (~700 bytes of PROGMEM)
#define PID_AUTOTUNE_MENU // Add PID auto-tuning to the "Advanced Settings" menu. (~250 bytes of PROGMEM)
//#define PID_PARAMS_PER_HOTEND // Uses separate PID parameters for each extruder (useful for mismatched extruders)
// Set/get with gcode: M301 E[extruder number, 0-2]
// If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it
// Creality Ender-3
#define DEFAULT_Kp 23.75
#define DEFAULT_Ki 1.76
#define DEFAULT_Kd 79.96
// Ultimaker
//#define DEFAULT_Kp 22.2
//#define DEFAULT_Ki 1.08
//#define DEFAULT_Kd 114
// MakerGear
//#define DEFAULT_Kp 7.0
//#define DEFAULT_Ki 0.1
//#define DEFAULT_Kd 12
// Mendel Parts V9 on 12V
//#define DEFAULT_Kp 63.0
//#define DEFAULT_Ki 2.25
//#define DEFAULT_Kd 440
#endif // PIDTEMP
NEW (2.0.7.2)#if ENABLED(PIDTEMP)
#if ENABLED(PID_PARAMS_PER_HOTEND)
// Specify between 1 and HOTENDS values per array.
// If fewer than EXTRUDER values are provided, the last element will be repeated.
#define DEFAULT_Kp_LIST { 22.20, 22.20 }
#define DEFAULT_Ki_LIST { 1.08, 1.08 }
#define DEFAULT_Kd_LIST { 114.00, 114.00 }
#else
#endif
