Currently printing out the pig that game on sdcard, zero problems so far
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Only thing I had to do, unlike the ender 3 where the z stop has T nuts hence can be adjusted, this has pre drilled/threaded holes, hence it's fixed. Bed was too far away, the wheels were so loose you could blow on them to move them. Had to elongate the holes to move zstop down a bit.
So far very very pleased. V Slot felt like they were self aligning rather than my ender where it felt like they were swinging on a pendulum
Hardest bit of assembly was for me to get the wheels on the y adjusted properly. 6 wheels, 2 eccentric one side, 1 the other
![3D Printer yet?](https://www.eevblog.com/forum/index.php?action=dlattach;topic=94559.0;attach=1026652;image)
Maybe I'm too OCD about this, but I spent ages getting it so you turn any of the 6 wheels and the Y axis moved moved. Logically (to me) I loosened the 3 eccentric wheels, lightly tightened the two on the left, making sure the middle wheel on the left could still grip, and making sure the outer two wheels the other side did too, then all I had to do was slowly adjust the right middle eccentric nut until it just gripped then all must be OK. The reality of course was completely different, very slightly adjusted middle right wheel, then other two right hand wheels were loose etc. Took ages to get them all just gripping but I finally got there.
No Cura profile for my printer, presume I can use CR10 S as that appears to be the closest printer to mine
Leaving it as is for a while, at some point I will fit BLTouch and touch screen and SKR mini, but for now, I'm just pleased it finally appears to be working
