Hmm, not sure whats going on, spent hours on this, not giving up.
I've made sure Configuration.h and configuration_adv.h are almost identical to those Xrunner posted. Only differences are either comments, or things where my version has things called slightly different, for example
XR: #if HAS_TRINAMIC
ME: #if HAS_TRINAMIC_CONFIG
or
XR: #ifdef PROBE_TEMP_COMPENSATION
ME: #if ENABLED(PROBE_TEMP_COMPENSATION)
or
XR: #if HAS_GRAPHICAL_LCD && HAS_PRINT_PROGRESS
ME: #if HAS_CHARACTER_LCD && EITHER(SDSUPPORT, LCD_SET_PROGRESS_MANUALLY)
First I'm having trouble flashing, keeps coming up with Eprom error (have tried initialising eprom first, original firmware still loads fine)
But looking through menu, things seem to be working
However, motors very very noisy.
Things get odd.
I re-flashed the original firmware supplied with the SKR board, motors still noisy. (sorry no vid)
Due to the original firmware aslo being noisy, I went back to square 1, I remove the SKR board and temporarily replace the original board and screen.
The motors are quieter than with the SKR:
Original board and firmwareI refitted the SKR and screen, still getting eprom error when flashing,
and as you can see, motor is noisier than the original board on both Marlin and TFT.
SKR Marlin with my firmwareSKR Touch screen with my firmwareSo, I re-flashed the original SKR firmware, and this time (unlike earlier) it's as quiet as a mouse
Original SKR firmware now quiet unlike earlierIt's also the same on the TFT screen.
Weird how earlier this didn't happen and they remained loud.
Anyway, I'm now trying to sort out why I keep getting this Eprom index error, then hopefully can put the newer firmware on and try mesh leveling.
I've been at this all day, now 17:00 and still stuck lol. It's not going to beat me
