Hmm. I use Marlin to level the bed, do it about 10 times, get it near perfect.
I then try the touch screen levelling. The home has a very very very slight catch of the paper, the other 3 corners the papers not touching the nozzle. So I spend a while levelling it with the touch screen bed leveller, get it near perfect, I then go back to Marlin and the paper is wedged solid under the levelling points.
Am I to presume if I intend to print with Marlin, I level with Marlin, and if I intend to print with the touch screen, I level with the touch screen?
Just want to check something weird isn't going on.
Thanks
