No, med was not trolling. med and I are old friends, and we happened to have a disagreement in thread. The fact you don't see that, and know that like adults, we worked it out, is exactly what I'm talking about. You only see ammunition to use in your attacks.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
You really ARE a well-known troll, you have earned this reputation, and I am sick and tired of defending you to my friends.
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
Your questions about which models I worked with, as you've correctly stated, were immaterial; I ignored them as the obvious attempt to drag me back into a semantic argument I'm already tired of that they clearly are.
Do you have any experience with any of the CReality or clone printers that bean and I have suggested? Or do you simply assume that because you battled your way through all those Prusa builds it's only fair to expect others to do so?
The disagreement we keep having here is NOT one of "how much quality" can you get out of a Prusa; you
can get quality out of a plywood RepRap build, especially if you have help. It's whether the "kit" is appropriately simple, pre-assembled and idiot-tolerant to be a good choice as a first build. It's over the amount of fettling required to get a usable print on your first build. What an experienced builder considers to be easy is not the same as what a noob will consider to be so. I learned those lessons the hard way through lots of
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
The Prusa kits STILL aren't even in the same league as the E3 for simplicity. Nor do they have the E3's proven track record of being a FDM printer that is just plain easy to live with. They require maintenance due to the choice of materials that just isn't there with an extrusion-framed build.
There are SO MANY printers out there which produce similar or better results to the Prusa, that it's hard to believe someone with your vast experience can't come up with some good firsthand reasons other than "these guys say it's good" and "I didn't think it was that bad".
I don't know... maybe it's a matter of philosophy, and you just click well with the Prusa crowd, and just don't see what I see in the comparative assache factor of the two kits as a first build. If that's the case, I guess I'll never be able to make you see it.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
For the difference in price, you can certainly start with a nice easy E3 or CR-10, THEN when you've gotten a handle on what you're doing, it's EASY and cheap to upgrade to linears & rods or sliders, making them every bit the equal of the Prusa (because hey, they ARE Prusa-derived), only on a more stable base so less fettling over the long run. Two of my friends from my old hackspace, and many popular figures online have gone exactly that route.
But there I go saying "These guys say it's good."
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
