EEVblog 1547 – Contacting the Voyager 2 Space Probe PART 1
How do you contact the Voyager 2 space probe? PART 1:
A detailed explanation by Richard Stephenson from the NASA Canberra Deep Space Communications Complex in Canberra on how the 70m DSS-43 dish at the CDSCC is used to still contact the Voyager 2 probe. You can follow Richard on Twitter: https://twitter.com/nascom1
NOTE: This video is a re-release from the EEVblog Discover channel from 2017, to hopefully find a new audience.
Forum: https://www.eevblog.com/forum/blog/eevblog-1547-contacting-the-voyager-2-space-probe/ 00:00 – How do you contact the Voyager 2 space probe?
03:14 – Voyager ISN’T the lowest signal level!
06:29 – The Failed Capacitor and the Best Lock Frequency
09:00 – Transmit uplink power
10:00 – System noise temperature
10:30 – S and X band receivers
11:42 – Mars Reconnaissance Ordbiter and the Signal to Noise Ratio
12:39 – Maximum Transmit power is WHAT?
13:12 – The effects of weather
14:16 – Power supply and backups
15:29 – The roll of the Deep Space Network
16:50 – Mag Roll Calibration
About EEVblog
Check Also
EEVblog 1621 – Mailbag: RadiaCode Radiation Monitor + LattePanda Mu Compute Module
More mailbag! A look at the RadiaCode Radiation Monitor, and the LattePanda Mu Intel N100 …
