Inventables X-Carve Time Lapse Build
Time lapse footage of Dave & David 2 assembled the Inventables X-Carve cutting/milling machine.
6.5 hours of build footage in 2 1/2 minutes
About EEVblog
Check Also
Heat Pump Hot Water System vs Gas Hot Water
Comparing gas hot system to a heat pump hot water system before I install a …
