EEVblog #744 – SMD Thermal Case Design – µSupply Part 15
Dave explains how to attach an SMD power transistor or regulator to a case to use as a heat sink in this design tutorial. And in the process talks about thermal design, the electrical/thermal analogy, and thermal vias.
This is Part 15 of the µSupply Power supply design series. Other videos are HERE
Forum HERE
SilPad datasheet
PowerPeg thermal PCB pin/turret
Saturn PCB Toolkit calculator
About EEVblog
Check Also
EEVblog 1628 – Home Solar Power Re-Install + Upgrade + FAIL
Reinstallation of the 5kW Enphase microinverter home solar power system, and installation of a new …
