EEVblog #622 – How To See Through Objects With A Thermal Camera
Dave shows you a handy tip on how to see *through* your product using a Flir thermal imaging camera with the cover *on*. Thus being able to maintain the correct airflow, whilst at the same time being able to view the thermal map as if the cover was off!
Forum HERE
About EEVblog
Check Also
EEVblog 1628 – Home Solar Power Re-Install + Upgrade + FAIL
Reinstallation of the 5kW Enphase microinverter home solar power system, and installation of a new …
