EEVblog #569 – Tour of an Analog TV Transmission Facility
David Kilpatrick from TXAustralia takes us on a detailed tour of the old decommissioned 10kW analog TV transmission system at the Artarmon facility in Sydney. How it all works from the broadcaster video input to final transmission output up the 180m broadcast antenna. Plus some teardowns of the old equipment that’s been used to transmit the Channel 7 TV signal in Sydney since 1981.
Copper rigid coaxial lines, waveguides, filters, splitters, combiners, converters, transmission valve, power supplies and all the equipment necessary to transmit a 10kW analog TV signal in a major city like Sydney.
Forum HERE
About EEVblog
Check Also
EEVblog 1628 – Home Solar Power Re-Install + Upgrade + FAIL
Reinstallation of the 5kW Enphase microinverter home solar power system, and installation of a new …
