EEVblog #515 – Battery Ionic Resistance Investigation
Dave investigates the ionic electro-chemical resistance of some Alkaline batteries under light multimeter input loading and an unusual physical battery phenomena, and explains how it differs drastically from the datasheet internal resistance value. He also finds a surprising result showing two types of Alkaline battery construction with different properties.
It demonstrates the usefulness of a high resolution bench multimeter.
Forum HERE
About EEVblog
Check Also
EEVblog1626 – YOU HAD ONE JOB! (Solar Power Install FAIL)
My solar power installer HAD ONE JOB but FAILED. A short story. LOL along as …
