Poll
Which scope in the 370 euros price range meets the requirements listed?
Rigol DS1052E
23 (45.1%)
Hantek DSO5202B
6 (11.8%)
Owon SDS7102V
12 (23.5%)
Siglent SDS1072CML
9 (17.6%)
UNI-T UTD2102CM
1 (2%)
Total Members Voted: 50
Voting closed: May 01, 2013, 01:03:22 pm
Author Topic: Year 2013 Oscilloscope Choices...  (Read 100601 times)
Offline rf-loop
Re: Year 2013 Oscilloscope Choices...
« Reply #225 on: September 11, 2013, 02:02:16 pm »
It was only some explanation why just Owon was previously one  wanted scope. This time when Owon was launched, what was Siglent in this time?
But Siglent have done good work and develop themselves (and products also of course) fast.
Still there need long march and deep hard work for develop better working culture,  services and products. But they really try. And they have good base for jump higher.
Siglent is good scope in this price class and  for many peoples it is good selection.
I know well also example Rigol DS1000E series. Previously I have sold these and also Hantek.
Also iSiglent  UI and features are ok. Not perfect but - if look money and what get...  not bad even if look with professional eyes for some kind of needs.
There is some stranges in FW but what do not have? My Digibox have much more bad FW and my neighbourg car have even more bad FW, real nightmare.
And as always - what is good, what is ok, what is not acceptable and what is not suitable - all depends just individual user needs and also other aspects.
Offline Orange
« Reply #226 on: September 11, 2013, 03:39:15 pm »
Is there no automatic grammar checker on this forum?
Offline Hydrawerk
« Reply #227 on: September 11, 2013, 11:32:39 pm »
Owon has good memory and ADC. But the acquisition speed is about 33 waveforms per second, which is bad. Owon also has no delayed sweep (zoom) mode. I would go for Siglent.
Offline Legit-Design
« Reply #228 on: September 11, 2013, 11:59:47 pm »
To properly understand Finglish you need to be finnish and know english.
Google chrome can point out spelling mistakes, but not grammar mistakes.
Offline stormbr
  • Country: br
« Reply #229 on: September 12, 2013, 12:05:49 am »
I bought one rigol ds2072 on the Tequipment.
The rigol ds1074z (4 channels) is a good choice too imho, or wait by the new releases of owon 4 channels.
« Last Edit: September 12, 2013, 12:09:36 am by stormbr »
Offline xtv
  • Country: br
« Reply #230 on: September 15, 2013, 06:15:50 pm »
Hi everyone,
I'm not experienced with oscilloscopes, but I'm willing to get one (affordable) for some time.. After playing around with RF converters, I decided that I need a device that can measure frequencies up to 150MHz (up to 200MHz would be a nice plus).
I get what Samples/sec means, makes perfect sense to me. But not Bandwidth.
Now, my questions are:
- Will the Owon 7102 give me a reasonably correct format of a 150MHz wave? (heard here that its bw can go up to 170MHz)
- My first option before seeing this thread, was the Siglent SDS1152CML 150MHz 1GigSa/s 2Mpt memory. Any good/bad recomendations about it?
My other option was the Hantek's 200MHz, specially for the "hackable" Linux firmware, but after seeing Dave Jones pointing such inaccurate measure in this video (which may, but doesn't seem to be caused by a bad firmware), I've discarded it. Btw, anyone knows if this have been fixed?
Thanks a lot!
Offline Hydrawerk
« Reply #231 on: September 15, 2013, 09:23:05 pm »
Dave's Hantek scope was a faulty model. Others should work better.
alm
  • Guest
« Reply #232 on: September 15, 2013, 11:26:29 pm »
No. If the bandwidth goes up to 170 MHz, then this means that the amplitude is at most -3 dB (-30%) down at 170 MHz. So a 170 MHz 1 Vrms sine wave will appear as a 170 MHz 0.7 Vrms sine wave on the screen. This is for sinusoidal signals. You can tell that there is a signal at this frequency, and its amplitude within say +/- 50%, but that's it.
Let's take the other extreme: a 170 MHz square wave. As shown in this video by w2aew, square waves are composed of multiple sine waves. The frequencies of those sine waves for a 170 MHz square wave are 170 MHz, 510 MHz, 850 MHz, 1190 MHz, and so on. The first harmonic will be 30% down. Imagine how much the higher harmonics are attenuated? Only the first harmonic will be visible, so the 170 MHz square wave will look pretty much identical to the 170 MHz sine wave. I.e. you can't even tell if your signal is sinusoidal or square, never mind its amplitude, distortion or rise time.
For a decent representation of the signal you might need say 5x more bandwidth than the fundamental frequency of the signal. A 1 *GHz scope would at least have shown the four harmonics, which allows you to tell that it's closer to a sine wave than to a square wave. You will probably need more bandwidth for square waves and pulses with fast edges, as you might encounter on digital signals. A 1 MHz pulse train from a micro or logic gate might still have a rise time of about 10 ns, requiring a 100 MHz scope to measure the rise time of this 1 MHz signal.
Offline EEVblog
« Reply #233 on: September 15, 2013, 11:40:28 pm »
I had a play with the new Rigol 1000Z scope, and it seems pretty good. Awesome bang-per-buck for a 4 channel scope. Incredible what you can get for the price these days.
Offline Hydrawerk
« Reply #234 on: September 16, 2013, 12:57:44 am »
It seems to me that those 1GSa/s ADCs are never gonna be cheap. You can have long memory, serial decoding, large high quality LCD, good waveform update rate... But you will not get 4×1GSa ADC.
On the other hand, TDS3054C is bloody expensive (13000USD!!), because it has 4×5GSa/s ADC, that is quite impressive... It is the most expensive part of the scope... But it is obsolete anyway.
Well, I am looking forward to the review. This DS1000Z scope might be very good for I2C debugging, because you do not need 1GSa/s there. And the signal generator is also impressive. I think that it is better than that generator in Agilent DSOX4000.
https://www.eevblog.com/forum/testgear/rigol-ds1104z-s/
« Last Edit: September 16, 2013, 01:04:34 am by Hydrawerk »
Offline olsenn
« Reply #235 on: September 16, 2013, 06:33:33 pm »
The cheapest DS1000Z-Series DSO seems to be not much cheaper than the cheapest DS2000-Series one, and with keygens available, the freely pimped out DS2000 completely kills the top-end DS1000Z. I aggree that those extra two channels are nice! However, it has a higher noise floor, fewer waveform updates/sec, a lower sampling rate (250MSa/s per channel isn't that great) and it seems to be a cheaper build quality.
Offline echen1024
  • 15 yo Future EE
« Reply #236 on: September 17, 2013, 01:06:03 am »
I really want a review of it, so I can see if the 1 vertical knob for 4 channels actually works out.
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
alm
  • Guest
« Reply #237 on: September 17, 2013, 03:08:44 am »
Why wouldn't it? It's not like it's the first 4-channel scope with shared vertical knobs. Some people dislike the idea of shared knobs, others don't care.
Offline EEVblog
« Reply #238 on: September 17, 2013, 03:13:32 am »
It's works, just like it does on any scope.
It's not as convenient of course, but it works.
You don't have a choice on such a small unit anyway.
Offline stormbr
  • Country: br
« Reply #239 on: September 17, 2013, 06:02:31 am »
Did you make a review of 1000z series  ? I wanna see a comparison between 1000z and 2000 series.
I wanna bought the ds1000z in the future.
« Last Edit: September 17, 2013, 06:05:13 am by stormbr »
Offline Hydrawerk
« Reply #240 on: September 18, 2013, 03:39:30 pm »
Well the shared knobs are good if you want a small and compact scope. BTW LeCroy and Hameg also use shared knobs at most models... Well, I rather do not like it. But the DS1000Z-S series is a good value for money, I think.
Offline echen1024
  • 15 yo Future EE
« Reply #241 on: September 19, 2013, 02:53:28 am »
Exactly 1000Z series is EXCELLENT value for money.
Offline EEVblog
« Reply #242 on: September 19, 2013, 03:17:30 am »
Shared knobs are pretty much mandatory for a small scope like this. It was even that way for the two channel DS1052E, now the 1000Z has 4 channels. Saperate knobs on that?, pretty much impossible.
Offline casper.bang
  • Pro SE, amateur EE.
    • BangBits
« Reply #243 on: September 19, 2013, 04:54:14 am »
Of course, the DS1052E also did away with a "Single shot" button, which is painfully annoying. The DS1074B/DS1104B/DS1204B (why do people refer to these as 1000Z?) thankfully does have a dedicated "Single shot" button. Btw. I still think Rigol should come out with a 2-channel version, they would totally own the newbie hobby marked if they did.
Offline Wytnucls
« Reply #244 on: September 19, 2013, 05:16:47 am »
Single shot set-up on the 1052E requires three button presses instead of one. While it may be a small inconvenience, it is hardly a deal breaker. Triggering will stay in that mode, even if the scope was turned off.
Offline iloveelectronics
  • Country: hk
« Reply #245 on: September 19, 2013, 05:52:09 am »
The DS1000Z is a new series, which may not be available in many parts of the world yet. I own one: https://www.eevblog.com/forum/testgear/rigol-ds1104z/
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Offline sync
« Reply #246 on: September 19, 2013, 01:15:50 pm »
But they could made it better. I hate how it's done on my DS1052E. There is no good indication which channel is selected. Only the tiny channel symbol on the screen. They should use bi-color leds on the channel button and highlight the selected one with a different color.
And i often accidentally switch a channel off instead of selecting it because it was already selected. There is already a dedicated off button. The channel buttons should not switch off, only turn on and select.
Offline quantumvolt
  • Country: th
« Reply #247 on: October 02, 2013, 04:04:11 am »
I unexpectedly got a tax refund, and before my wife and children get it all, I will buy a scope. I now use an external sound card from fleabay (USD 6.99  ;D) that I have modified with a DC level shifter and buffer/amplifier.
I have to buy from fleabay or China factory (I live in Thailand - only one of the Chinese brands represented here - and expensive). I am doing analog and transient stuff down to milliseconds. Also serial, I2C, SPI, some waveforms and other repetitive things up to a few hundred kHz, and 16 MHz micro controller (but want something faster) .
I only have a few wishes:
3-400 USD
Big display
USB
(GPIB)
(VGA)
These threads are too big to read through. I just want a scope. What do I buy?
EDIT I saw forum member 'marmad's video and have decided for the Owon SDS7102. Has anyone bought from eBay aidetech_us USD 420? And is the 3 year warranty valid for international customers?
Thanks.
« Last Edit: October 02, 2013, 08:00:44 am by quantumvolt »
Offline echen1024
  • 15 yo Future EE
« Reply #248 on: October 02, 2013, 04:51:43 pm »
A Rigol DS1074Z for US 585 if you can afford it. 4 channels for an AMAZING price. Otherwise, get a Siglent. Solid FW, decent build, god features, etc...
Offline Zbig
« Reply #249 on: October 02, 2013, 05:40:34 pm »
[..] Otherwise, get a Siglent. Solid FW, decent build, god features, etc...
Which button does that? I wouldn't mind one or two of those  ;)
