Author Topic: Vector-Vod ISO-V-AC III WP-32 Variable Isolation Transformer  (Read 6029 times)
Offline GADTopic starter
« on: January 16, 2016, 07:06:07 am »
I scored this thing for a good price online and would love some input.
First the good - it seems to work! :) The Variac portion works great, and from what I can tell, the mains are indeed isolated as desired. Here are some gut shots:
My concern is that the three-prong outlets on the front are grounded to the chassis. I've read countless contradictory articles about why this is good vs. bad, but I bought it for isolation of DUT for my scope, so I'm thinking for that purpose it may not be the right solution.
Where I'm getting a bit confused is with these readings:
Both hot and neutral to ground are open until it's turned on, after which the meter will register 8M resistance.
Are these readings normal given that the hot/neutral are isolated but the ground/chassis is not? The concept kind of hurts my head and it's been a long day.
Re: Vector-Vod ISO-V-AC III WP-32 Variable Isolation Transformer
« Reply #1 on: January 16, 2016, 07:10:54 am »
Oh, and if anyone has a manual I'd love to get a copy!
« Reply #2 on: January 18, 2016, 05:52:18 am »
Bump
Offline TheSteve
  • Living the Dream
« Reply #3 on: January 18, 2016, 06:06:29 am »
Never seen the unit before but I see it measures leakage of some sort, so that may explain the 8 meg ohms to the earth connection. It does indeed have an isolation transformer and a variac from the looks of it. Being the earth pins are all connected it wouldn't give you any isolation if you plugged a three pronged device into the output. You will need to a quick "mod" or two for it to fully isolated to meet your needs.
VE7FM
Offline Docholiday
« Reply #4 on: July 17, 2017, 11:35:41 pm »
did you ever get a manualmfor it?
Offline Charlesjohnson29
« Reply #5 on: December 24, 2017, 12:55:27 am »
GAD
You pasted some great pictures of the Vector WP32 power supply.
I have one that is missing the 2 integrated circuits on the Right Hand side of the supply.
If possible could you supply the part no. of these two chips.
I know this is asking a lot but I would like to restore it.
Thanks Charles
Offline Audiocluster
« Reply #6 on: February 28, 2018, 04:52:01 am »
Did anyone say MANUAL ?? :P  Ask and you shall receive....eventually.
Thanks to Mars at Antique Radios
http://antiqueradios.com/forums/viewtopic.php?f=8&t=336335
Send me a PM and I'll either email or send you gooDriv link (if I can get it to work) for "A nice clean PDF" of manual. Thanks again ........ Mr M !!!
Charles
« Reply #7 on: February 28, 2018, 01:22:27 pm »
This fabulous - thanks!
