Author Topic: Software and manual for Feeltech FY2300  (Read 18490 times)
Offline GodwynTopic starter
« on: March 13, 2016, 09:02:23 am »
Hello there,
I have bought a Feeltech FY2300 Generator from china.
The device seems to work well, i have not tested the precision yet though.
I can only tell the waves match with the osciloscope.
The CD included should contain drivers, software and manuals.
The problem is thay my cd doesn't work. I contacted the seller but i get no responce.
So i wonder if someone owns the same device and would be so kind to upload the cd for me.
Here is a free service to do this: https://www.wetransfer.com/ there are others if you prefer.
Thanks in advance.
« Last Edit: March 13, 2016, 09:43:45 am by Godwyn »
The following users thanked this post: Ben7128
Re: Software and manual for Feeltech FY2300
« Reply #1 on: March 16, 2016, 02:17:26 pm »
Wow am i the only one that owns this?
Offline nctnico
« Reply #2 on: March 17, 2016, 04:53:23 pm »
Appearantly. It does look like a neat generator for the money so I expect you won't be the only one who owns one for long. Did you open a non-conforming dispute?
Offline Chriss0422
« Reply #3 on: March 21, 2016, 07:01:29 am »
Hello Godwyn,
I just bough this Generator. I zipped the CD and you will find it at this link: http://we.tl/xNtI4FqHvN
The zip package doesn't contains all the CD because some folders are for others devices such as FY220S...etc.
May I ask you one thing ? When I received my generator I'm almost sure it was in version 2.0 and now it is in version 2.1
I suspect the PC sofware to have upgrade my device (even if the PC software seems very basic).
Could you confirm that by verifying your current version (sys menu) ?
Anyway, this is a good device for this price. But it contains small bugs, not on frequency precision.
I ask yesterday FeelTech if they have a place to report bug but I'm not optimist since you had no answer in your side...
Regards.
Offline SimonD
« Reply #4 on: March 21, 2016, 06:36:16 pm »
can anyone do some tests with square waves low and hi frequencies and post some images ?
(rise, fall time, spikes, distortion etc)
Thanks in advance !
Offline jam-elec-device
« Reply #5 on: April 08, 2016, 06:42:05 pm »
I just got my FY2300 6M and the CD is completely blank :(.
The link listed above is no longer working. Can the link be updated so that the download would be available?
« Reply #6 on: April 16, 2016, 01:19:54 pm »
Hello Godwyn,
Regards.
Hi there,
My device got firmware v2.1
Can you please upload the files again?
Greetings,
« Reply #7 on: April 16, 2016, 02:20:59 pm »
Thanks in advance !
Here are 2 pictures,
1 at 50hz
1 at 2Mhz
Greetings,
The following users thanked this post: SimonD
Offline SimonD
« Reply #8 on: April 19, 2016, 09:14:05 am »
Thanks for the reply Godwyn,
well, it was as i expected ... not so bad for Hobby use.
Moreover That You Pay Is What You Get ....
Offline Dd
« Reply #9 on: June 14, 2016, 06:35:35 pm »
For those who might be interested - new model is out - FY2300H
http://en.feeltech.net/html/dynamics/show_49.html
Notable upgrades:
1) Up to 60MHz sine
2) Sampling rate 250MSa/s
3) 14 bit?
3) Waveform memory 8192 samples
No lots on eBay or Ali yet, only few offers on Taobao
https://world.taobao.com/item/522225150189.htm
30 MHz - ¥898.00 ($136.70) - software limited?
60 Mhz - ¥1298.00 ($197.58)
I wonder what would be eBay prices then (+$30?). My kung-fu is not strong enough to buy on Taobao directly.
Offline pascal_sweden
  • Country: no
« Reply #10 on: June 15, 2016, 11:08:32 am »
Would be cool if they also release an updated and improved version for the bench model!
Offline maxiq4
« Reply #11 on: August 03, 2016, 10:20:16 am »
Im just buy a FY2300 6mhz with TFT lcd display`s generator
its all working well except arbitrary waveform
I can all controlled over usb cable on pc software
but when I draw a signal and trying send to generator, its only waiting and not change output.
is it damage? what are you think?
Offline maxiq4
« Reply #12 on: August 04, 2016, 07:13:41 am »
check another pc and its working well  :-+
Offline ja4
« Reply #13 on: December 09, 2016, 12:35:02 pm »
Hi there, I also own a FeelTech FY2300 6Mhz, and it works like a charm, very happy with it.
What I would like to know is, if this 6Mhz is in hardware or is it software crippled?
My version at this moment is V3.3 (Model FY2306).
Online Kleinstein
« Reply #14 on: December 09, 2016, 01:03:27 pm »
The slower speed might be different HW, especially a slower DAC and slower output amplifiers. A picture from the inside could give a clue.
Offline kenjo
« Reply #15 on: August 06, 2017, 04:17:38 pm »
Hello.  Just joined...
This is the official download site for FeelTech (english translation).
http://en.feeltech.net/html/download/
Offline JohnEE
« Reply #16 on: July 10, 2020, 04:23:47 pm »
FeelTech FY6300 with 14-bit DACs is an inexpensive ($82US) improved version of the FY2300.
The main differences between FY6300 and FY2300 series are as follows:
1. The output frequency of FY6300 series sine wave can reach 60MHz (FY6300-60M), and the maximum output frequency of square wave can reach 25MHz. Parameters Table.
2. Added AM, FM, PM, ASK, FSK, PSK, VCO modulation functions!
3. The sampling rate of FY6300 series is upgraded to 250MSa / s, and the outline of high-frequency signal output is clearer;
4. The FY6300 series uses 14-bit high-speed DA integrated circuits (the performance far exceeds the DA solution made by the resistor network). At 5V output, the waveform ladder is as low as 0.3mV;
5. The FY6300 series waveform storage depth is upgraded to 8192 * 14bits, which can restore signal details with high accuracy;
6. The phase resolution of FY6300 series can reach 0.01 degree, users can control the delay of two signals more accurately;
7, FY6300 series duty cycle adjustment accuracy can reach 0.01%; square wave rising edge and falling edge time can be adjusted. When the instrument is setting square wave output, press F4 button to switch between duty cycle and rising edge time, So that the scope of application of the instrument is wider!
8. The FY6300 series adopts a new power supply design solution, which eliminates the disadvantages of small-amplitude signals interfered with by the power supply noise of handheld instruments. (10mV small signal still has perfect signal characteristics)
https://www.aliexpress.com/item/4000842494136.html?gps-id=pcDetailBottomMoreOtherSeller&scm=1007.14976.179138.0&scm_id=1007.14976.179138.0&scm-url=1007.14976.179138.0&pvid=ec4b4bb5-646e-478b-acf2-99372171586c&_t=gps-id:pcDetailBottomMoreOtherSeller,scm-url:1007.14976.179138.0,pvid:ec4b4bb5-646e-478b-acf2-99372171586c,tpp_buckets:668%230%23131923%2358_668%23808%234094%23174_668%23888%233325%2316_4976%230%23179138%2341_4976%232711%237538%23823_4976%233223%2310815%237_4976%233104%239653%233_4976%233141%239887%236_668%232846%238110%23347_668%232717%237561%23349_
