I've scored a nice thing today at the flea market for about 20€:
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_181147_zpse439dae6.jpg)
It's a Soviet (actually Lithuanian) oscilloscope/meter combo. From what I've found it was made by company called 'Rimeda'. It's single channel, specced up to 10MHz, but reportedly working well up to 20MHz, which is not bad considering the overall technology level of this thing. The timebase goes from 50ms/div down to 50ns/div, vertical ranges are from 5V/div down to 5mV/div. It has an integrated 3.5 digit multimeter which displays digital measurement result using CRT. It has an external trigger input, altough it looks like a banana jack, not a BNC. It's a very small and compact device for an analog oscilloscope (it weighs about 3kg).
I bought it as supposedly working, but the guy didn't know much about the thing. It was pretty banged up (scratches and stuff, input BNC is damaged, intensity and contrast knobs are loose) but it turned out to be working quite well and the CRT seems to be in a very good shape. Originally, this unit came with a front cover, which also served as a storage compartment for probes, but this one came without the cover or the probes (which by the way were shitty, as I've read somewhere). My unit was made in 1991 and it's serial number 19833. The power cable had been replaced at some point, but the old one was just cut and an extension was added.
It appears, that it has never been opened before - seals which cover a screw on the bottom are still there:
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_202101_zps10cabd33.jpg)
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_202117_zpsf63abe30.jpg)
After looking inside and briefly checking that there is no major damage inside I've powered it up and voila:
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_202444_zps70cd8704.jpg)
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_203144_zps1485a9ad.jpg)
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_203835_zps22bf2fab.jpg)
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_204411_zpsc1af6518.jpg)
Some shots of the internals before disassembly:
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_202504_zps84600779.jpg)
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_203621_zpsf7dbdc27.jpg)
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_203628_zps9d86baf4.jpg)
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_203633_zps6d610110.jpg)
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_203648_zps57dba84b.jpg)
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_203714_zpsce1cc5d3.jpg)
![](http://i1261.photobucket.com/albums/ii588/poorchava/c1-112a/IMG_20150215_203852_zps76ad2efe.jpg)
I've found some schematics for the thing and I'll try to convert them to PDF at some point.
In general the scope is all-semiconductor. Vertical input amplifiers and and other related stuff are discrete analog, using soviet components. The digital parts (multimeter, some parts of timebase(?)) are built using soviet versions of 7400 logic (mainly K555LA3 which is an equivalent of 74LS00 quad NAND). There seems to be a lot of some white powdery residue on the internals and obviously shitload of dust and general dirt, but no signs of moisture ingress.
Stuff to do:
-clean everything
-replace the damaged BNC connector
-replace electrolytics
-sort out the power cable
-do something with the peculiar DMM probe connector. Either obtain an original probe or replace the connector with 4mm banana sockets (or 2mm if 4mm won't fit)
-clean potentiometers or replace them if possible (some fo them are quite unique mechanical contraptions)
Stay tuned
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
