Is this a good meter for the price?
Based on the pricing at tme.eu, absolutely.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
FWIW, it's a well built meter that meets its CAT ratings. A number of other members own them it seems, and are quite pleased based on their posts. I don't have this particular model, but my BM857A is rather well built IME (BM867's daddy). Although it's primary use is on a bench, it gets a fair bit of automotive use as well, so has seen a fair number of ~1m or so drops to no ill effect.
Oops and is it better than the 867?
Yes, the BM867 is it's little brother (slightly fewer features & a bit less accurate). See link below.
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
If you don't need the extra features however, it's also an excellent meter & will save you some funds (useful if on a tight budget).
1. I know it can be confusing & not the easiest bits to find, but all of this has been covered before in multiple threads (searching prior to posting questions will win you points with other members
2. For convenience:
Hope this helps.
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
