I'm not sure, but a ratio of 9:1 and the long wire antenna would indicate a unun which is used for impedance matching a random long wire to a 50 Ohms antenna input. One of the wire terminals is for the long wire and the other one is ground (same as the SMA's ground, the antenna's ground isn't used usually). For a dipole you would need a 4:1 balun.
