Author Topic: GDS-2000A series New economic oscilloscope by GW Instek comes to market  (Read 148737 times)
Offline HydrawerkTopic starter
Hello, what do you think about the new GDS-2000A series? GW Instek web here. You can download manual or specification there. It seems to be a serious competitor for Rigol DS2000 series. The price for GDS-2000A is quite the same. 100 MHz, 2-channels  GDS-2102A is sold for $1,143 at Testequity.
Please do not confuse the GDS-2000 with GDS-2000A, they are totally different. See attached pictures. Yes, I do not know, why they chose the GDS-2000A name... :-//
And features, as specified by the manufacturer.
*300MHz/200MHz/100MHz/70MHz Bandwidth ,2 or 4 Input Channel
*2GSa/s Real-time Sampling Rate and 100GSa/s Equivalent Time Sampling Rate
*2MegaPoints Record Length (When using one channel, probably...)
*1mV /div to 10V/div of Vertical Range
*1ns/div to 100s/div of Time Base Range
*80,000 wfm/s of Waveform Update Rate (I wish it was true...)
*8 inch 800*600 High Resolution TFT LCD Display (Very good!)
*Built-in Segmented Memory and Waveform Search Functions to Optimize the Efficiency of Record Length
*Zoom Window and Play/Pause can Rapidly Navigate the Waveforms
*36 Automatic Measurement Functions Offers Various Measurement Selections
*Optional 8 or 16 digital channel with Logic analyzer(MSO)
*Optional Function Generator (but probably only to 3 MHz)
*Flexible Remote Control Connectivity(Standard:USB ;Option:LAN/GPIB)
Finally, it has a better XY mode than Rigols... It has cursors in XY mode.
Update:
Photos and screenshots here. Please note that I was not an experienced user of this scope, when I took the pictures.  :)https://plus.google.com/photos/106264218831814439783/albums/5857196858625060337
Dave's video
Teardown made by Dave
« Last Edit: May 28, 2013, 11:36:47 pm by Hydrawerk »
Offline EEVblog
Re: GDS-2000A series New economic oscilloscope by GW Instek comes to market
« Reply #1 on: January 11, 2013, 12:18:28 am »
It has 4 channels and mixed signal capability. The Rigol DS2000 is no match for that.
Dave.
Offline EEVblog
« Reply #2 on: January 11, 2013, 12:20:42 am »
I just noticed mention of the function gen  (the two unlabled connectors presumably, dual channel?)
But they have no specs on that...  :-//
Dave.
Offline EEVblog
« Reply #3 on: January 11, 2013, 12:21:50 am »
Clearly aimed at the Agilent 2000X series.
Even has the multi channel demo signal connectors.
Dave.
Offline EEVblog
« Reply #4 on: January 11, 2013, 12:29:22 am »
Ah, dual channel 3MHz DDS function gen. It's in the datasheet.
LAN/SVGA is optional, just like on the Agilent.
Dave.
« Reply #5 on: January 11, 2013, 12:52:14 am »
According to the user manual, the "Trig Out" signal can be set to these connectors. So it should be quite easy to measure if it really has the 80,000 wfm/s of Waveform Update Rate. You would only need a frequency counter.
I wonder if this GW Instek is better made and if it has less bugs than Rigol DS2000... Who knows?
GW Instek is a company founded in 1975 with quite good raputation... http://www.gwinstek.com/en/Brandorigin_0.aspx
Rigol was founded in 1998... http://www.rigol.com/html/about/history.shtml
« Last Edit: January 11, 2013, 01:11:18 am by Hydrawerk »
Offline mAJORD
« Reply #6 on: January 11, 2013, 12:57:35 am »
Yeah, the func gen and logic analyser appear to be plug in upgrade modules.
$245 for the func gen
$570 for 8c Logic
from tequipment.net
Offline mAJORD
« Reply #7 on: January 11, 2013, 01:08:09 am »
Can't seem to edit in tapatalk, and work has blocked eevblog (lol) so sorry about these posts..
Was going to say, the upgrades also appear cheaper than Agilents equivilent "soft" upgrades.
Only downside is no bw upgrades
Offline Hypernova
  • Country: tw
« Reply #8 on: January 11, 2013, 02:40:27 am »
Looks like serious competition to the 3000X, with the wavegen and MSO options it is feature wise very close yet way cheaper.
For a 4+16 MSO with wavegen at 100MHz:
$1,694+$830+$245=$2,769
[edit]
Just saw that it has color mode on the digital phosphor too, that's pretty nice. Not having colour mode was one of my disappointments with my 3000X especially after seeing it in action on the Lecroy's at work.
« Last Edit: January 11, 2013, 02:56:26 am by Hypernova »
Offline Bored@Work
« Reply #9 on: January 11, 2013, 06:58:19 am »
Instek makes nice oscilloscopes, and everything is fine as long as they work. They let us badly down when we needed to get one repaired. They pointed to the distributor we bought from (authorized and all that), who wasn't at all equipped to service the oscilloscope and shipped the oscilloscope to yet another distributor who also failed to service it. From there it went to a third distributor, still not a real repair workshop. The couldn't even come up with a cost estimate. Month later it was returned unrepaired to the first distributor who returned it unrepaired to us. And in the end we were blamed for dareing we asked to get it repaired, and the first distributor had the galls to bill the shipping costs for that desaster to us.
During all this Instek "support" in Taiwan couldn't care less. The showed the typical Asian attitude, going into stelth mode the moment there was a problem.
We scraped the oscilloscope and blacklisted Instek.
Offline Nermash
« Reply #10 on: January 11, 2013, 07:27:07 am »
I am glad to see that they fixed IMHO the bigest failing point of their GDS 3000 line, which was abysmally small capture memory depth of 25 kpoints...
Offline andersm
« Reply #11 on: January 11, 2013, 10:31:44 am »
Here in Finland we've gotten our Instek scope repaired a couple of times without problems.
« Reply #12 on: January 11, 2013, 08:44:41 pm »
Well, the GDS-2000A is probably so new, that nobody has bought it yet...
« Reply #13 on: January 11, 2013, 08:50:21 pm »
Well, do you think that Rigol, Owon or Tekway are better? Anyway, if I needed a oscilloscope for my company, where the instrument runs 12 hours a day, I would buy an Agilent, or so. But for hobby use the GW Instek could be OK...
Offline Chalky
« Reply #14 on: January 11, 2013, 10:28:34 pm »
Has anyone seen these working?  Claiming 800x600 screen resolution, but all the screen images I can find look really crappy - not just shonky in-house fonts, it looks more like they're doing pixel doubling.
Offline marmad
  • Country: aq
    • DaysAlive
« Reply #15 on: January 11, 2013, 10:42:18 pm »
The problem with the GW-Instek DSOs seems to be getting your hands on one to try. On paper, both this and the GDS-3000 series seem very nice - but I couldn't even get GW-Instek to respond to a couple of emails when trying to locate a 3000 series to evaluate. Perhaps I wasn't a big enough customer? I never did figure out what the problem was.
In any case, even though their DSOs appear well-designed and feature-laden, if they really want to succeed in the lower end of the market, they really need to do some work on their distribution and customer-interface mechanisms - even before tackling after-sales support.
Offline digsys
    • DIGSYS
« Reply #16 on: January 11, 2013, 11:44:01 pm »
Agreed. I've tried SEVERAL times over the last 2 yrs to get responses from them on a few of their products.
Even applied for QTY pricing - as LONG AS they answered some questions ... NADA or bugger all reply.
I also don't like that the FEW resellers they have, ALL have pretty much EXACTLY the same price ! Sus.
I'll definitely be waiting until we get a few reports from brave? pioneers :-)
Offline mAJORD
« Reply #17 on: January 12, 2013, 12:42:13 am »
Found this on their site.. Some doofus saved it in JPG though instead of PNG   ::)
http://www.gwinstek.com/webmanage/IMG/uploadfiles/DS0020.jpg
I'd say the opposite vs those brands..   Instek are positioned more towards budget commercial than 'hobbiest' . Like a poor mans HP / Agilent.
I wouldn't lump Rigol in with OWON either..
Offline marmad
  • Country: aq
    • DaysAlive
« Reply #18 on: January 12, 2013, 12:43:37 am »
Combing through the data sheet and owner's manual, it mentions that the DSO can capture up to 2048 successive waveform segments with a time-tag resolution of 8ns.
Hmm... do they mean the same thing by those terms as I understand them to mean? If so, that implies a waveform update rate of 125M wfrm/s - the reciprocal of 8ns. For example, the Rigol DS2072 can capture up to 65000 successive waveform segments at a minimum time-tag resolution of 20us - the reciprocal of 50k wfrm/s.
Offline Chalky
« Reply #19 on: January 12, 2013, 09:27:16 am »
I call bullshit on GW-Instek (and Hantek & Owon).
I am very sus of these budget scope makers who have rushed out larger screen 'resolutions'.  I have had a good zoomed-in look at the images for both their 800x600 screens, the Owon is certainly using vertical pixel doubling for the waveform display.  The Instek seems to be doubling (or worse) as well, but some doubt must be given due to no decent images available yet.
Have a look at the attached images - every single waveform pixel is actually 2 dots tall, by 1 wide (compare to 1x1 graticule dots for reference) .  Now I realise that screen resolution does not equal measurement resolution, but if the scope is joining the dots, as per the default display mode, then I expect an expensive 800x600 scope to actual use that resolution for drawing the bl**dy lines!  This is not just 'oh we've used a 2-pixel thick line' - the displayed line only steps up or down 2 pixels at a time.  Seems to me the usual story - buy Rigol or better!
« Last Edit: January 12, 2013, 09:47:52 am by Chalky »
Offline mAJORD
« Reply #20 on: January 12, 2013, 11:21:50 am »
I'm not 100% sure how they normally go about it, but on such a square waveform (i.e the Instek screenshot) , I think you'll find the Rigol , and others for that matter would still show two pixel jumps on an 8 bit DAC. I can't see how you could interpolate those pixels below 2..  Maybe at a pinch on the second high transision there where it's a bit rounded off.
The fact the little noise blips on the top are 3 pixels high suggests it's not pixel doubling??
I think you'd need a Sinewave screenshot before even suspecting that to be honest  :-//
Offline Chalky
« Reply #21 on: January 12, 2013, 12:59:54 pm »
Hi mAJORD, yeah I agree re the Instek 2000A & square wave, there might be something else going on there.  Have attached a sine wave showing more clearly.  If it's pixel doubling, it's the wrong approach, since the 8-bit ADC would then need 256x2=512 pixels to display, most of these scopes have less than that in visible waveform area on screen - so then it becomes not a 'nice' display issue, they are actually not able to represent all available information.  I think their displays are just terrible.  Contrast that with Rigol and Agilent who seem to be doing their line(between 2 samples)-to-bitmap rendering correctly.
Offline andersm
« Reply #22 on: January 12, 2013, 03:09:37 pm »
Is it a real issue beyond looking ugly? For accurate readings you have to use the cursors anyway, trying to count pixels doesn't really work. The display issues could be solved by using anti-aliasing, but the used chipsets may not be up for that.
Offline tinhead
« Reply #23 on: January 12, 2013, 04:17:04 pm »
i have to quote this.
First of all you can't simply take a unknown pictures from unknown setups and compare them.
Attached pictures from Tekway/Hantek, screen_1.png shows a typical screenshot, here with avg. wave. We can perfectly see
the 2x2 pixels when we zoom (screen_1_zoomed).png <- i've made a small scale so you can count pixels, one DIV is 50pix high.
But simply let snap that what the DSO is capable to do -> screen_1.png which is a noisy waveform. Can you see the diff
in the zoomed picture ? So yes, Tekway/Hantek can do 1x1 pixels on the screen.
« Reply #24 on: January 12, 2013, 05:52:29 pm »
There will be a trade fair in my city... http://www.amper.cz/ The Micronix company will probably display GW Instek products there. http://eshop.micronix.cz/merici-technika/elektricke-veliciny/osciloskopy/digitalni/stolni/gds-2102a.html
Well, do you think that Rigol is better than GW Instek?
