« Reply #8 on: January 26, 2019, 04:46:23 pm »
OK
I connected the new Relay.
And look at that nice stable output on the integrator.
Changed the usual M1
All electrolytics.
Have 15.01 and -15.01
6.42 and -6.45 Reference
5.10 on the 5 volt line
Only one problem left to manage...
the -15V line is not always 15V sometimes on turn on it is -13.5 +-
Repeated on-off cycling and I get my -15.01 back.
When it is -15.01 it is stable until I cycle power switch.
Same when it is 13.5
Only thing I can think it might be now is that tantalum I haven't changed C11.
Guess I should work on that after lunch.
« Last Edit: January 26, 2019, 04:50:18 pm by Johnny10 »
![](https://www.eevblog.com/forum/Themes/default/images/ip.gif)
Logged
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
