Hello.
I recently got myself a Nan Tan mechanical keyboard which uses the famous yellow ALPS mechanical switches. The feeling is really fantastic and beats and Cherry switches.
However, it will not work. What happens is that when I start my PC, after BIOS start loading, the LED's flashes as it does with all keyboards, it turns dark or off again as normal, but never return as functional. So I initially thought it was the electrolytic cap (1) was old, so I replaced it (same value), but the same symptom is present. A flash and then nothing. It is plugged into the ps/2 port via an adapter. I tested it on two computers, same symptom.
There are two IC's on the board.
NTC6151N: Propitiatory Controller IC
GD74LS05: HEX Inverter.
My question is if anyone know how to start fixing the issue with the keyboard ?
--- EDIT ----
I am currently on an IBM Model M (1991) so I know the ps/2 port is functional.
