This is in answering bingo600's question in my other post about Fluke 343a calibrator fix.
But from my point of view ... Even nicer work with the backlight of the 3457A ![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I just got one of those , and would love to see some pics and a description .... So i can do the same ...
I thought others may be interested too.
This HP 3457A backlight mod. is based on others method with my takes. But, in any case, be very careful and I can't guarantee all info are 100% accurate or correct in your case (do it on your own risk, so to speak).
The three pictures and comments there-in should give some general info. The steps are,
1). The key materials: white LED stripe(e.g. ebay), reflector (e.g. broken laptop LCD), and light guide (e.g. broken laptop LCD). You can replace them with the similars.
2). Remove the LCD assembly from the 3457a and measure the gap (HxLxW) between the PCB and the LCD glass (I don't have the numbers at hand). These will be used to prepare the reflector and light guide. Be careful the connector pins are VERY fragile and strangely some are aged worse than others.
3). Cut the reflector and light guide into size to fit into the gap. Make sure no scratch and no chipping when cutting. The light receiving side is better on the original edge.
4). Remove the LCD glass part from the assembly. They are held together by two holders with mechanical force.
5). (!!!Be very careful!!!) Peel off the old reflector on the back of the LCD glass. The two are glued together by tape like glue. The safer peel force should go along the glass surface direction instead of normal to it.
6). Clean off the sticky residue on the back of the LCD glass without scratching it. Scratching can damage the light polarizer on the glass (I was told). A lot Alcohol can do the job, but paint thinner will be more effective.
7). Assemble back the LCD assembly. But don't connect the connectors yet.
8 ). Insert into the gap in the assembly with the new reflector and the light guide. They should be in loose fit.
9). Construct, connect and temporary glue you LED light source as shown in the picture.
10). Connect the connectors without force the pins in. The original connector clip should not be used any more. Then, screw the back cover on as shown in the picture. It will press on the pins with minor force to make good contact.
11). Slightly adjust the position of the light source to reach best light uniformity. Black permanent mark can be used to damp the light intensity. You may want to change resister value to adjust the light intensity too.
The result:
![](https://www.eevblog.com/forum/projects/hp-3457a-lcd-backlight-mod-(also-for-3478a)/?action=dlattach;attach=46635)
Backlight installed (Edited: J702 connection should be to 1 and 2):
![](https://www.eevblog.com/forum/projects/hp-3457a-lcd-backlight-mod-(also-for-3478a)/?action=dlattach;attach=46679)
Before backlight installed:
![](https://www.eevblog.com/forum/projects/hp-3457a-lcd-backlight-mod-(also-for-3478a)/?action=dlattach;attach=46631)
Materials needed:
![](https://www.eevblog.com/forum/projects/hp-3457a-lcd-backlight-mod-(also-for-3478a)/?action=dlattach;attach=46633)
