Author Topic: el cheapo oscillator  (Read 23476 times)
Offline dannyfTopic starter
« on: March 22, 2015, 02:53:55 pm »
Experimenting the oscillator on this link: http://www.b-kainka.de/bastel3.htm
and decided to simplified it to just 5 parts: 2 transistors, 1 resistor, 1 inductor and 1 capacitor.
Simulated well so I built one.
« Last Edit: May 27, 2015, 09:52:30 am by dannyf »
Re: el cheapo oscillator
« Reply #1 on: March 22, 2015, 02:55:39 pm »
Here it is, living on a breadboard.
The transistors are lowly 2n5401, and the inductor came from a dead cfl lamp. I used two 1k resistors in parallel in the base.
« Reply #2 on: March 22, 2015, 02:58:17 pm »
What it looks on the scope, as is.
120Khz makes it quite interesting. the inductor is about 20uh.
« Reply #3 on: March 22, 2015, 02:59:48 pm »
This thing oscillators without that capacitor there - distributed parameters I guess - at 1.7Mhz.
« Reply #4 on: March 22, 2015, 03:01:29 pm »
The amplitude is fairly constant from 120Khz to 1.7Khz: 60mv Vpp.
Current consumption is 4ma @ 5v and 2ma @ 2.5v. Reasonably frugal.
You can probably make it go higher with a better layout and faster transistors: the 2n5401 isn't known for its speed.
« Reply #5 on: March 22, 2015, 04:03:28 pm »
With simpler wire routing, I got it to work at 30+Mhz - the inductor was a simple 3" long copper wire.
« Reply #6 on: March 22, 2015, 04:33:34 pm »
77Mhz with a pair of 3906s.
Offline dom0
« Reply #7 on: March 22, 2015, 04:51:23 pm »
Unloaded emitter followers also make great UHF oscillators. Although, not very stable ones.
Offline paulie
« Reply #8 on: March 22, 2015, 05:33:31 pm »
I was surprised to see most of the 2.4ghz and higher oscillator circuits were 2 transistor. I  have some 11ghz bipolars and 2-24pf variables in my junk box and would love to build a microwave range GDO. I thought single transistor was the way to go but maybe not.
« Last Edit: March 22, 2015, 05:40:51 pm by paulie »
Offline djacobow
  • takin' it apart since the 70's
« Reply #9 on: March 22, 2015, 05:42:03 pm »
Did you reverse the circuit?
Online SeanB
« Reply #10 on: March 22, 2015, 06:12:22 pm »
Gunn diode you really only have one component, and it is not even a device with any PN junctions in it. You do need a tuned conductive box to house it, which determines the resonant frequency though.
Almost any power Mosfet ( VN10KM) can make a very low component count VHF oscillator, just use long wires on the leads and keep them close to each other.
Offline tszaboo
« Reply #11 on: March 22, 2015, 06:38:33 pm »
I've got 77MHz from a SN74AUP3G04 ala ring oscillator. I actually wonder a single 74x00 can do in terms of stability. Maybe I'll hook up one to a counter one day.
Online SeanB
« Reply #12 on: March 22, 2015, 06:45:24 pm »
IIRC they go up to about 40MHz, though you can tune them using the supply voltage somewhat. CMOS inverters do have a much lower frequency, but a lot more linear voltage control. I have seen a Frequency-voltage converter that used a CMOS inverter supply current as the conversion, as it is almost linear with applied frequency with no load.
« Reply #13 on: March 22, 2015, 07:06:00 pm »
I hope so. I was actually running on 2n5551 (npn). 2n5401 is pnp.
Point-to-point construction probably will allow it to go to the FM band.
Offline dom0
« Reply #14 on: March 22, 2015, 07:50:04 pm »
I think I saw that one too... must have been either a Linear or TI appnote... not sure which...
Online PA0PBZ
« Reply #15 on: March 22, 2015, 08:00:22 pm »
Just tried with 2 BFR91's head to tail and a little U as the coil. Easy 400MHz and probably well over 1GHz with some cutting.
Online Zero999
  • 0999
« Reply #16 on: March 22, 2015, 08:28:01 pm »
Awhile ago I built one based on this schematic:
http://www.next.gr/rf/uhf-circuits/simple-uhf-oscillator-l11838.html
Except I used SMT inductors and capacitors, a small air core inductor, consisting of some enamel wire wrapped round a PCB drill bit to form it and the BFT92. It was assembled on a very tiny piece of stripboard. It worked to over 1GHz and would probably have gone higher but the frequency counter topped out at 1.3GHz.
« Reply #17 on: March 22, 2015, 09:13:53 pm »
Built one from a pair of s9018. Over 130Mhz.
edit: picture added.
« Last Edit: March 22, 2015, 11:35:47 pm by dannyf »
Offline paulie
« Reply #18 on: March 22, 2015, 11:33:25 pm »
Singles ahead by TWO LENGTHS. (1300 vs 400 mhz) And there goes SWIFTY!
« Reply #19 on: March 23, 2015, 01:18:33 am »
Implementing this on a dual gate mosfet would be interesting.
Offline babysitter
  • pushing silicon at work
« Reply #20 on: March 25, 2015, 01:13:54 am »
Yeah, I saw the opening post oscillator used for Respiratory inductance plethysmography before - basically the inductor was wound around a person and the breathing movement retuned the oscillator. Also a nice method to detect if someone is sitting on a chair or lying in a bed :)
Project idea for the trainee pops up - build such an oscillator and see what you can do with it, employing different coils etc.
I'm not a feature, I'm a bug! ARC DG3HDA
« Reply #21 on: April 08, 2015, 10:06:28 pm »
If two transistors are too much for you, here is a one-transistor version:
« Reply #22 on: April 08, 2015, 10:08:39 pm »
Living on a breadboard.
« Reply #23 on: April 08, 2015, 10:09:34 pm »
oscillating at 500Khz happily.
« Reply #24 on: April 08, 2015, 10:10:39 pm »
The oscillator easily starts up in oscillation and isn't picky about transistors - S9018 (1.1Ghz) works just as well as a 2n5551 (150Mhz).
Higher resistor values (lower collector current) give better sine waves.
