Author Topic: DIY wall chain clock  (Read 6437 times)
Offline Kaptein QKTopic starter
« on: September 03, 2014, 10:45:55 pm »
It uses 3D printed parts (mostly painted),
an Arduino Nano (code written in C in Atmel Studio 6),
a L298N dual H bridge (no micro-stepping, but uses software controlled PWM soft-stepping, completely silent)
and a Nema17 stepper motor (coil resistance 32 Ohm).
Video:
3D files:
http://www.thingiverse.com/thing:450985
Code:
 * chainclock.c
 * Created: 8/29/2014 11:06:29 PM
 *  Author: Rolf R Bakke
#include <avr/io.h>
void delayMicroseconds( unsigned long delay) {
static unsigned long timeStart;
unsigned long timeCurrent;
if (delay == 0) {
TCCR1B = 0b00000011; //set TCNT1 to run at 250kHz.
TIMSK1 = 0b00000010; //turn on Timer/Counter1, Output Compare A Match Interrupt
timeStart = (unsigned long)TCNT1 << 2;
return;
do {
timeCurrent = (unsigned long)TCNT1 << 2;
} while (((timeCurrent - timeStart) & (unsigned long)0x0003ffff) < delay);
timeStart = timeCurrent;
return;
int main(void) {
DDRD = 0b11111111;
PORTD =0b00001001;
TCCR0A = 0b10100001;
TCCR0B = 0b00000001;
delayMicroseconds(0);
while(1) {
for(uint8_t i=0xa0; i>=0x01; i--){ //ramp down coil A
OCR0A = i;
delayMicroseconds(10000);
PIND = 0b00000011; //flip coil A polarity
for(uint8_t i = 1; i <= 5; i++) delayMicroseconds(250000);
delayMicroseconds(50000);
for(uint8_t i=0x01; i<= 0xa0; i++){ //ramp up coil A
OCR0A = i;
for(uint8_t i=0xa0; i>=0x01; i--){ //ramp down coil B
OCR0B = i;
PIND =  0b00001100; //flip coil B polarity
delayMicroseconds(50000); //adjust this delay to correct the clock
for(uint8_t i=0x01; i<= 0xa0; i++){ //ramp up coil B
OCR0B = i;
Offline miguelvp
Re: DIY wall chain clock
« Reply #1 on: September 03, 2014, 11:30:01 pm »
Nice, and to set the time you just need to pick up the chain and place it in the right time :)
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #2 on: September 04, 2014, 02:53:55 am »
Lovely project. :-+
Seeing that your circuit is powered by a wall wart (is it AC?), you could use the line frequency as a super accurate time reference (many clocks do that). No need to play with delays and hope that you get it right. ;)
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
« Reply #3 on: September 04, 2014, 08:59:58 pm »
It is a DC adapter.
The delay routine uses a hardware timer, and current delay is started from where the previous ended.
Thus code run-time does not affect the delay time.
All delays in the loops adds up to the required 4.5 seconds per step, and I have not seen any inaccuracy yet.
We will see how good it is over long time :)
Offline JohnWard
    • Youtube jjward
« Reply #4 on: September 04, 2014, 10:39:33 pm »
AC line frequency is typically rather inaccurate, and will vary depending on the total load on the system.
UK line frequency in real time: http://www2.nationalgrid.com/uk/industry-information/electricity-transmission-operational-data/
Offline SArepairman
  • wannabee bit hunter
« Reply #5 on: September 04, 2014, 11:50:47 pm »
i thought they deliberately slow/speed it up sometime to sync up line clocks.
Offline Dave
  • Country: si
« Reply #6 on: September 05, 2014, 04:02:29 am »
The instantaneous frequency is all over the place. The long-term accuracy, however, is very good.
That is exactly what they do.
Offline VK5RC
« Reply #7 on: September 05, 2014, 08:34:14 am »
THE time nut Tom V B has measured the accuracy of mains http://leapsecond.com/pages/mains/.
Great clock.
