Author Topic: ShaoGe SMC4-4-16A16B Offline CNC controller  (Read 14600 times)
    • Mike's Electric Stuff
« on: February 21, 2016, 04:45:15 pm »
ShaoGe SMC4-4-16A16B Offline CNC controller - surprisingly little info out there on this unit.
It's surprisingly reasonable....
Day Job: Mostly LEDs
Re: ShaoGe SMC4-4-16A16B Offline CNC controller
« Reply #1 on: February 21, 2016, 07:15:59 pm »
Some Chinglish documentation found here :
http://chinaplccenter.com/support/pdf/CNC/Four-axis-cnc1508.pdf
Offline Stonent
« Reply #2 on: February 21, 2016, 08:02:40 pm »
Is there any evidence of a signal going to the missing FT232 chip?
« Reply #3 on: February 21, 2016, 08:10:18 pm »
no - nothing comes out, no response to some random stuff thrown at it
Offline Stonent
« Reply #4 on: February 21, 2016, 08:16:08 pm »
If you can dump the firmware and make it publically available there might be evidence of a manufacturer inside or at least maybe someone can do some tweaks on it.
Offline orion242
« Reply #5 on: February 23, 2016, 05:58:26 am »
Can you shoot a link to that CNC machine? Can't quite make out the model in your video.
I assume you think its worth the coin invested?
« Reply #6 on: February 23, 2016, 09:19:45 am »
Just look for CNC 3040
Online all_repair
« Reply #7 on: February 23, 2016, 11:36:29 am »
Thank you Mike.  I shall be getting the other offline controller, DDCSV1.1 .  If you compare the sale figures on Taobao, it can be very helpful in getting the correct "cheap" controller.
« Reply #8 on: February 23, 2016, 11:35:37 pm »
Will be interesting to compare the two units.
One issue I've found with the one I have is if you pause, re-zero and restart a job  something odd happens to the offsets (tool crashy time!) , so safest to reload the file.
Other than that it seems happy running an 8000-odd line file doing a pocket with 0.01mm pass depth for the next-but-one video....
Offline khomouda
  • Country: eg
« Reply #9 on: April 21, 2019, 04:47:50 am »
Hi Mike, are you still using this controller, I bought one and fiddling with some understandable keys. how do I configure the probe? how do I configure work coordinate systems, the machine is working and homing, but that is mostly it. I also can't get the spindle frequency less than 24 which is its minimum, there is no minimum to configure...thanks a lot
« Reply #10 on: April 21, 2019, 11:45:32 am »
I now use the DDCS unit as it has MPG support
Offline khomouda
  • Country: eg
« Reply #11 on: April 21, 2019, 01:44:53 pm »
Can you enlighten me in setting the working coordinates, and about the min spindle frequency.
