Author Topic: DIY Cheap resistor decade substitution box  (Read 129806 times)
Offline vtlTopic starter
« on: July 22, 2011, 04:39:34 am »
After seeing these adjustable resistor substitution boxes I decided that they would be a nice addition to any person fiddling with electronics regularly. I don’t particularly like potentiometers for this purpose as you usually have to have a pretty decent quality one otherwise it can be hard to dial in a precise resistance.
After looking on the interwebs, it became clear that these things are quite expensive, usually utilizing expensive rotary switches. We’re talking on the order of $50-$200 for what really is just a resistors hooked up to some switches. Surely there’s a cheaper way?
I saw these thumbwheel switches on eBay for a reasonable price, just $5 for 10. These can be stacked and locked together, with the numbers ranging from 0-9. The clips aren't particularly strong so glue may be needed to keep them together.
Design
Looking at the spacing it seems like it could be ideal for 0603 resistors. I decided not to go this route for now, I had a look at element14 and when you take into account minimum order quantities, the costs can rise pretty quickly when buying precision resistors.
The biggest challenge to a resistor box is making it accurate. The box just puts the resistors in series to make up the value so the error of the resistors can add up pretty quickly and give you pretty wild deviation from what number you dial in. Now accuracy was not a large factor for me, as long as it was somewhat correct that would be fine for me.
I wanted a box that would do 1R, 10R, 100R, 1K, 10K, 100K and 1M. Even if I had got 0.05% resistors, at 100k this could produce an error of 50ohms, quite large considering this device is supposed to do 1R steps. Clearly the larger resistors require a very good tolerance or you’ll end up with large offsets from the value entered.
So I concluded that this box would not be intended on being a precision instrument. It would be just a nice thing to have for circuits that require irregular resistances and I could just hook it up to a multimeter if I needed more accuracy. It would be similar to a pot but with a huge range and very fine and precise adjustment.
On eBay they sell resistor kits pretty cheaply. A while ago I bought 2000 1% assorted resistors for $11 which is quite nice. I decided the accuracy would be terrible no matter what tolerance I use so I figured 1% should be good enough for hobby usage.
These thumbwheel switches are much more compact than those huge resistor decade boxes I’ve seen. Instead of making up some kind of housing, the resistors should fit directly on the PCB and should not increase the overall size at all. The wiring is fairly simple but it may not be immediately apparent when looking at the switch. You have a common pin and 10 other pins corresponding to each digit. For a 10M (9,999,999R), 7 digit box this will require 63 resistors, with 9 resistors per digit.
This is a simplified drawing of the switch with only 6 contacts drawn. You would measure the resistance between the common and pin 0. In this case the wiper is switched to 3 so the measurement would be 3xR. You can daisy chain these up to provide more resistance, just attach the common to pin 0 of the next decade.
And here is the end result. It can be quite time consuming I guess if you work fast you can do 1 switch every 10-15 minutes or so. Its probably a good idea to check each switch before combining them up, I ended up gettign a few soldering errors and reworking it when its all glued and soldered together can be a bit tricky.
Accuracy
The accuracy will depend greatly on what value is shown on screen. If you use only 1 resistor from each decade then this will be highly accurate, but if you use many resistors then the error will add up. So I’ve tested by setting each range to 9 and recording the reading. REL was used when the resistor box was set to 0 to null out the resistance of the test leads
The percentage error looks quite bad at the lower resistances but the actual absolute values are quite small. We’re talking less than 1.5ohms at the errors of greater than 1%.
While probably not lab grade equipment I’m pretty pleased with the accuracy results. In general, when dialling in high values you tend to need to trim it out slightly. For this device, most of the time the device will give a value less than the desired value. I suppose it is possible to improve the device by adding some trimmers for each decade and might be handy if you’re just building up a 1K box.
Overall cost estimate:
The parts cost is pretty cheap for this:
$5.45 for 10 thumbwheel switches
$.0055*63= $0.35 for 63 1% resistors
Prices in AUD
So surely this beats the hell out of those crazy expensive rotary switch boxes in terms of price and portability.
So go out and build your own, I’d be interested to see what kind of error if 0.05% or better resistors were used.
The following users thanked this post: ar__systems, Apofview
Offline gregariz
Re: DIY Cheap resistor decade substitution box
« Reply #1 on: July 22, 2011, 05:58:48 am »
If only you had posted a day earlier! I finished a couple builds last night.
The only tip I have is make sure you clean the flux off well as you'll see it on the Meg Ohm switch settings.
Online IanB
« Reply #2 on: July 22, 2011, 07:54:29 am »
Very neat idea and good job--but I'm a bit confused about your accuracy estimations.
1% is 1%, whether it be 1% of 1 ohm or 1% of 100k. The circuit doesn't know the difference, and the 1% 100k resistor is no less accurate than the 1% 1 ohm resistor. (Consequently, a resistance value of 134,968 ohms, say, is rather meaningless and also not likely to be useful in any practical application.)
Also, the error doesn't "add up" when you put resistors in series. It remains exactly the same at 1% no matter how many resistors you combine. (The variance changes, but the mean error doesn't.) This means that if you put ten 1k, 1% resistors in series you will get a 10k, 1% resistor. Therefore, I would say that if you have an error of 2% on your 9 ohm value, it is either because the resistors themselves are out of spec or you have an inaccurate measurement. (At low resistance values you also have to worry about extra circuit resistances like switch contact resistances getting in there, but your measurements don't indicate that problem.)
« Reply #3 on: July 22, 2011, 09:00:15 am »
Ah yeah thats right regarding the numbers, but what I meant was that the absolute values in ohms do add up. I didn't say 9 1% resistors in series = 9% tolerance.
Percentage errors will roughly stay the same but when youre building a device thats supposed to have 1ohm resolution, youll never get near that kind of precision at the higher values which is the point I was trying to get across.
Offline hacklordsniper
  • Country: hr
    • HackLordSniper
« Reply #4 on: July 22, 2011, 09:18:32 am »
Just a quick note. I bought few of these "resistor kits" and some of them had all resistors labeled wrong and i guess they were factory discarded  and resold by clever Chinese guy :)
Offline Kiriakos-GR
« Reply #5 on: July 22, 2011, 10:46:11 am »
I am aware that this thread are about cheap decade boxes.
But I have to add a link of my own decade box.
It is a good example  about making with your hands, one box that in the market retails at 1500$,
with the lowest possible cost.
The low in Watt decade boxes, they must be easy to repair too.
The low in watt resistors, they can easily get damaged for high current.
And so its not wise to follow dirt cheap solutions, but to play safe by making something better.
And even by looking at your home made box, you will have with it and all the memories by the experiences that you earned by making it, with your own hands.  :)
https://www.eevblog.com/forum/index.php?topic=1148.0
Online IanB
« Reply #6 on: July 22, 2011, 10:15:34 pm »
Actually you will have 1 ohm resolution, but you won't have 1 ohm accuracy. Although as I was saying, I can't think of a 100k resistor where 1 ohm accuracy is of practical use. (Maybe a high precision voltage divider or bridge circuit, but in that case a trim pot would likely do the job.)
Offline ejeffrey
« Reply #7 on: July 22, 2011, 10:45:15 pm »
Not quite.  Unless you take special precautions, 10,000 ohms will not be within 1 ohm of 9999 ohms, nor will it even be greater.  In the language of DACs, typical resistor decade boxes have poor DNL and are not monotonic.
Offline george graves
« Reply #8 on: July 22, 2011, 11:00:51 pm »
Looks great!  Nice work.
Thanks for posting that up.  I just ordered 20 of the switches, and will make a box or two when I get the chance.  Seems like a really great budget/alternative.  I could never pull the trigger on the $100 worth of parts.  This is great.
Offline gregariz
« Reply #9 on: July 22, 2011, 11:14:46 pm »
If you don't need so many resistor levels, or precision resistances.. another cheap option is
http://www.elexp.com/tst_subk.htm
Online IanB
« Reply #10 on: July 22, 2011, 11:17:55 pm »
Oh, you are correct of course, thanks for pointing that out. Oops.
(Goes off to think about putting 10,000 one ohm resistors in series...)
« Last Edit: July 22, 2011, 11:21:01 pm by IanB »
Alex
« Reply #11 on: July 22, 2011, 11:28:08 pm »
Relevant, if not mentioned already:
http://www.bourns.com/data/global/pdfs/3680.pdf
Offline Kiriakos-GR
« Reply #12 on: July 22, 2011, 11:31:02 pm »
Tell us the price Son !!   ;D
Offline Conrad Hoffman
    • The Messy Basement
« Reply #13 on: July 23, 2011, 12:15:58 am »
I use resistance boxes constantly and have acquired quite a few over the years. Switch costs are always the primary problem when you build one, followed of course by the resistors. General Radio Corp made their own switches and wound their own mica card resistors- very precise and handle quite a lot of power if you don't mind the inductance. For low values it's easy to wind your own resistors if you get a roll of constantan or other solderable resistance wire.
You might get some more ideas from some stuff I've written on KVDs and precision resistor dividers. Look at the Mini Metro Lab and the Hamon Divider. With nothing special you can do ratios at the 10-100 part per million level. Absolute resistance value is a bit more difficult because you need at least one known standard. I also like the BCD methods because it takes fewer parts for both an R box and a C box. I suppose nobody builds L boxes, but you certainly can.
Offline tomlut
« Reply #14 on: July 23, 2011, 01:04:18 am »
I may be wrong but i think the total tolerance is the geometric mean of the individual tolerances.
So %Total = sqrt(%1^2 + %2^2 + %3^2 + ... %n^2)
Or if all the tolerances are the same:
%Total = sqrt(n.t^2) where
n = number of resistors
t = resistor tolerance
So for 10 x 1% resistors in series you are looking at a total tolerance of 3%.
No I won't fix your TV for a carton of beer.
Online IanB
« Reply #15 on: July 23, 2011, 01:30:53 am »
Maybe this depends on the definition of tolerance?
My understanding of resistor tolerance is that it is the maximum allowed deviation from the nominal value. So a 100 ohm resistor at 1% tolerance is guaranteed to be in the range 99 to 101 ohms with a degree of statistical certainty. (I don't know what that degree is.)
I like to look at this by taking an example. Suppose we have 10x 100 ohm resistors that we are going to put in series to make 1k, and suppose each of these resistors is at the lower limit of tolerance at 99 ohms. We will therefore have a nominal value of 1000 ohms and an actual value of 990 ohms. The deviation between actual and nominal will be 10/1000 = 1%. In the worst case, the accuracy of 10 resistors in series is no worse than one resistor. However, if we suppose the individual resistors have a random deviation from the nominal value, then some negative and positive errors will cancel out when ten resistors are combined. If so, the likely error on the combination will be less than the error individually. I think statistically you end up with a smaller variance around the mean value when many resistors are combined in series compared to a single resistor of the same value. But this presumes an equal and random distribution around the nominal value of each resistor. If there is a systematic error in the individual resistor values, then this systematic error will be reinforced when resistors are placed in series and the mean value will assert itself as being different from the nominal value.
Offline johnboxall
  • You do nothing, you get nothing.
    • Books, services and more:
« Reply #16 on: July 23, 2011, 01:48:28 am »
Congratulations - you made it on 'hackaday.com'
http://hackaday.com/2011/07/22/resistor-substitution-box/
Offline Wartex
    • http://headsplosive.com
« Reply #17 on: July 23, 2011, 02:33:35 am »
vtl, thanks for providing an eBay link so everybody else can buy those.
Offline johnboxall
« Reply #18 on: July 23, 2011, 02:36:40 am »
« Reply #19 on: July 23, 2011, 03:12:13 am »
Yeah sorry about that, I'd normally put the link up but the links are generally dead within a month. I used the keywords "thumbwheel switch"
This is the exact auction and arrived in a week which is quite fast for something on ebay:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=220806571911&ssPageName=STRK:MEWNX:IT
The pcb traces are actually different in the images than the one I got, the switches I bought look the same as the ones that tronixstuff posted
Offline insurgent
« Reply #20 on: July 23, 2011, 03:37:29 am »
FWIW, Looking around it appears resistors in series you would use the weighted average:
(R1*T1 + R2*T2 + ... Rx*Tx) / R1 + R2 + ... Rx
For parallel:
((1/R1) + (1/R2) +... (1/Rx)) / ((1/R1*T1) + (1/R2*T2) +... (1/Rx*Tx))
« Reply #21 on: July 23, 2011, 10:10:43 am »
In other words, for identical values, the variance of the resistors adds up, but since the standard error of the mean is s/sqrt(n), this neatly cancels out. For resistors with the same tolerance, SEMseries=sqrt(n)sqrt(s2)/sqrt(n).
Offline mitpatterson
« Reply #22 on: August 01, 2011, 07:44:05 pm »
hmm, the ones i ordered(think from the link tronix gave) and i got mine today, but they only have 5 contacts, it appears for like 3, it connects common to both 1 and 2, like 7 it connections common to 4 + 2 + 1. definitely odd/different
Uncle Vernon
« Reply #23 on: August 02, 2011, 10:53:41 pm »
That's a BCD coded switch, an entirely different animal. Check the specs of what you ordered, there is an error somewhere in the process if you ordered a decimal switch.
Offline tekfan
  • Country: si
« Reply #24 on: August 03, 2011, 11:48:47 am »
Did you by any chance make this?
http://www.electricstuff.co.uk/capbox.html
One can never have enough oscilloscopes.
The following users thanked this post: oPossum
