Author Topic: Stone as a heatsink?  (Read 7608 times)
Offline alexigTopic starter
« on: July 20, 2011, 12:04:23 pm »
Hi all,
I just pulled a product apart and found that one chip had a stone based material (or something similar) on it as a heatsink ???.
This is the first time I've seen this, is it common and/or just a way to cut costs? This board also had a proper heatsink on a larger chip.
Alex.
Offline scrat
Re: Stone as a heatsink?
« Reply #1 on: July 20, 2011, 12:39:48 pm »
Could be a ceramic (sintered) material..
Offline sacherjj
« Reply #2 on: July 20, 2011, 01:51:22 pm »
It could impulse heat sink needs and using the thermal mass of the ceramic as a buffer.  I'm not familiar with the heat transfer characteristics of ceramics vs more normal heat sink materials.
« Reply #3 on: July 20, 2011, 03:16:29 pm »
Nice, first time I've seen that on a real product.  Read about them, since they are porous and thermally conductive they have more exposed surface area than aluminum.
http://www.electronics-cooling.com/2010/11/micro-porous-ceramic-heat-sinks-enhance-heat-dissipation/
http://www.ceramtec.com/index/products/ceramcool/ceramic-heat-sinks/
I've seen them in some LED bulbs, but thought at first they were insulators.
Offline sacherjj
« Reply #4 on: July 20, 2011, 03:28:48 pm »
Interesting.  Good links, thanks.
Offline scrat
« Reply #5 on: July 21, 2011, 07:26:28 pm »
I remember ceramic packaged ICs, like Intel's 8088 or something similar... Even older than me!
However, I think some PC processors have been packaged in ceramics until quite recent days.
You could recognize them from the "metallic" sound (with respect to plastics) and roughness of the surface.
« Reply #6 on: July 22, 2011, 11:25:51 am »
Yes, I remember many of those, I always thought it was some sort of metal alloy that felt like ceramic.
