I am watching the linked YT.
I do not like the part that describes thermal expansion. The deduction is flawed. It assumes no longitudinal strain is acceptable in the design while we know the strain is not a problem today - take a look at continuous (welded) railroads.
Thermal expansion is a design parameter. Besides, there are other materials available, like concrete, composites, elastomers, etc. As for steel, the 50mm expansion of 100m tube over [0:40]DegC seems like impossible to overcome. Otoh, that is a strain of only 100MPa (G=210GPa) or +-50MPa if you weld it at 20DegC. Any steel is capable of 50MPa. The one used for industrial piping goes up to 500MPa. Mind this is only the expansion part and the construction is subjected to other factors (vacuum, rust, terrorists, thieves, etc).
I would NOT use steel for members at compression, especially where the mass plays no role. I believe the steel is a temporary solution and the precast reinforced concrete + elastomeric joints are more likely to be a viable solution because of the cost and durability.
The idea that if the tube gets ruptured at any place and people inside die instantly because of the vacuum is also flawed. The capsules are pressurized and if the tube is punctured and filled with atmospheric air (gradually, via size-limited hole) then the drag would increase gradually and the capsule would eventually slow down. For God's sake that is not 600km of single piece of pipe and some locks are needed
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
You can die there when you derail or exceed G, but OTOH slowing down 900km/h (250m/s) at 5G (50m/s2, at emergency) takes lousy 5 seconds. Just let some air into a tube in a controllable manner. Ok, that is 625m to a standstill but dude, I would not exaggerate, at least you cannot hit the moose on the road.
Hitting a coke can with a ball
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Where is the BUT?
As of the emergency exiting, I think it should be presented in relation to emergency exiting when
KLM + Pan AM meet on one runway. How about then?
The weakest part of the project is its capital cost and technological challenges of the scale. It competes with airplanes so it is not hard to calculate the borderline cost of the trip of the hyperloop. Make it more expensive and people won't buy it.
