Author Topic: Smoke from a cheap meter  (Read 13899 times)
Offline tom66Topic starter
« on: February 21, 2011, 02:19:37 pm »
Bought these dirt cheap (£2 each) multimeters as throwaway meters which I could use to measure some things that might damage my more expensive BK 2709B. Little did I know I'd be throwing one away after just a week of use. I'm not sure what made it go (I think I overloaded the current range - it has no fuse), but it still kind of works (shows various random readings), it just doesn't read anything sensible. I'm thinking I can give it a fitting funeral, any ideas?
alm
  • Guest
Re: Smoke from a cheap meter
« Reply #1 on: February 21, 2011, 03:12:04 pm »
Just keep in mind that using cheap meters for dangerous jobs may injure or kill you. Those safety features that make good meters more expensive are there for a reason. Using cheap meters for risky jobs is wrong, I would only use them on low-voltage, current-limited circuits (eg. batteries with a high output impedance, or lab supplies), and leave the dangerous stuff to quality meters that have a better chance of protecting the user.
« Reply #2 on: February 21, 2011, 03:25:33 pm »
Purpose of these was for measuring low voltage and relatively high current (less than 5A) stuff. Given how close the 10A current shunt is to the 1000V input, I wouldn't trust it for measuring a 9V battery.
Offline apex
    • Thoughts of a nerd
« Reply #3 on: February 21, 2011, 03:29:55 pm »
Well, but they're cheap!
If you keep enough distance, you can use them.
Just watch the blog with Dave and Doug Ford blowing up some multimeters.
It is indeed true that more expensive multimeters have more safety features, but it just saves you a scratch from that distance and then it's dead.
Cheap mutlimeters are a good idea.
They might burn, they might disintegrate themselves, everything better than a 10k$ multimeter just going bang!
You could look for a multimeter with fast HRC fuses.
That could do the job too, but HRC fuses are expensive, too!
apex
alm
  • Guest
« Reply #4 on: February 21, 2011, 03:59:14 pm »
False economy.
Sure, not every circuit has enough energy to be dangerous. A CR2032 battery is unlikely to be able to deliver any significant current for example, or a lab supply set to a low current/voltage limit. 9V batteries can deliver more power. Car batteries even more.
Actually they tend to survive most minor abuses (like measuring mains on the ohms setting), which would blow up cheap meters. Catching fire is also a cool failure mode of cheap meters, as long as it's not in your home. The high energy pulse in that video is not the only way a meter can die. For example, with a steady 30A, the meter is unlikely to blow up, but will probably overheat (if unfused) and possibly catch fire.
If you sell them.
You don't exactly need to spend $10k to get a fairly safe meter (even the $50 ones Dave reviewed were better than this, and certainly the $100 ones). And everything is better than $10k going bang? Really? How much is your house worth? How much is your life worth? How much is someone else's life worth?
Offline Waifian
« Reply #5 on: February 21, 2011, 04:04:45 pm »
Good thing you didn't get hurt. Looks like the hole in the back may have made it to a hand if it was being held.
« Reply #6 on: February 21, 2011, 04:11:43 pm »
Aside from the safety issues of cheap meters, I'm still looking for a way to give it a fitting funeral. My meter is reading random numbers. I put some low power resistors inside it and blew them up (100W into 0.25W resistors), next to the ADC/LCD driver IC, the epoxy melted slightly but it's still working!
I do like cheap meters for this low power stuff. The meter was smoking quite a bit before the hole in the back formed, I actually left it on more as a curiosity, as I knew it was pretty dead past that point.
Offline FreeThinker
  • Truth through Thought
« Reply #7 on: February 21, 2011, 04:28:34 pm »
Tom66 Where did you get those meters from? There are a couple of people I don't like very much who I'm would like to have one. ::)
Machines were mice and Men were lions once upon a time, but now that it's the opposite it's twice upon a time.
MOONDOG
« Reply #8 on: February 21, 2011, 04:29:20 pm »
eBay.
Alex
  • Guest
« Reply #9 on: February 21, 2011, 04:44:17 pm »
Lol, Quality Certificate sticker, PASSED!
You learnt your lesson now, you are still here, and I also hope you will spread the news about dirt cheap multimeters, it seems people still use them. Maybe an international awareness campaign is needed to stop people from buying these pieces of junk.
« Reply #10 on: February 21, 2011, 04:51:52 pm »
Guys, I knew about cheap meters BEFORE I bought these. I have owned many cheap meters before. Primarily it was intended for somewhat dangerous stuff, and I was also planning to use this for measuring two quantities - my BK 2709B can measure volts or amps, but not both. They are actually pretty accurate; I compared them. The cheapie read 35.88V, the BK read 35.96V, tried it on most ranges, within 1% accuracy for all DC volts, tended towards the low side of measurements. I blew it up purely because of stupidity.
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #11 on: February 21, 2011, 05:06:46 pm »
I don't have any problem using cheapo meters for measuring comparatively low voltages or currents either. I even get paranoid holding my Flukes when I'm measuring mains, so I don't think I'd be within a metre or 2 of a cheap meter. Strictly low energy stuff. I wonder how much current actually went through that.
Anyway, do you have a mate with a 7.5 tonne truck or something a bit heavier that could be persuaded to squash it? Drop from a stupidly high bridge onto somewhere safe?
« Reply #12 on: February 21, 2011, 05:48:09 pm »
I want to watch it squirm, since it almost bloody killed me! (joke, just imitating Dave.) I tried submerging it under water, and it still works! I have a 35V power supply, any bets on what it will go up to?
« Reply #13 on: February 21, 2011, 06:00:27 pm »
It died at 30V  :D but nothing else happened, display just went blank, didn't even get warm. Time to start probing 35V against parts of the chip! I suspect it's the ICL706, which would rate it at 15V.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #14 on: February 21, 2011, 06:36:07 pm »
These are great photos, and thanks for sharing.  It shows again, what 'extra's you get when you get a reputable meter, and what happens with a cheap meter.
I've 2 suggestions, you can salvage the DMM for parts, the LCD looks to still be good, or you can mail the whole thing to your equivalent government product safety bureau to have them investigate whether this type of DMM should be sold in your country.
Best Wishes,
 Saturation
Offline Bored@Work
« Reply #15 on: February 21, 2011, 06:38:13 pm »
You are a slow learner, aren't you?
« Reply #16 on: February 21, 2011, 07:14:21 pm »
What? I fully understood the risk of using such a meter. I was just somewhat surprised when it failed so quickly. I had an old cheapie very similar to this one for about 2 years before I dropped it and it broke, entirely my fault.
Offline Neilm
« Reply #17 on: February 21, 2011, 07:59:48 pm »
As I work for a company producing measurement equipment and work with someone who sits on the IEC61010 commitee I would report it. OK you may have bought it on EBay but the seller may still have broken the law and the next person who buys one of these metermight not understand the dangers.
Yours
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
« Reply #18 on: February 22, 2011, 01:13:33 am »
Yours
Neil
It's not CAT rated or anything like that, so I don't think there's an actual case for saying it was even trying to be safe in the first place.
Offline Polossatik
« Reply #19 on: February 23, 2011, 02:04:00 pm »
what to do with it?
hum...
turn it into roadkill? Might be fun with a slow motion camera watching it going *pats*
Put a little buzzer or siren in it that goes off on a few positions besides on that gives dancing numbers, put it somewhere in a public space with a "do not turn" sign - people like to do what they are told not to do and watch them jump back if it goes "beep"
Use it as lotto/random number generator - take pictures with 3 sec interval or so and process that using python (need to add an arduino or lego somewhere so you get on hack a day)
buy a few of those and make a geek outfit with lots of beeps and wires and then try to pass a TSA checkpoint
I'm sure i can find more after a couple of beers, but i'm still at work now :)
Real Circuit design time in minutes= (2 + Nscopes) Testim + (40 +120 Kbrewski) Nfriends
Testim = estimated time in minutes Nscopes= number of oscilloscopes present Kbrewski = linear approx of the nonlinear beer effect Nfriends = number of circuit design friends present
Offline saturation
    • NIST
« Reply #20 on: February 23, 2011, 02:51:52 pm »
I don't recall the details, but there is a minimum required by any product for safety as required by the EU and IEC to be sold as a testing device, CAT rating isn't necessary.  It must have a CE stamp on it to be sold in EU, and that means conformance with the IEC directive.
Yours
Neil
Best Wishes,
 Saturation
Alex
  • Guest
« Reply #21 on: February 23, 2011, 03:25:02 pm »
Make sure its the proper CE mark with the right spacing between C and E. The Chinese CE mark products with fake CE marks where the C, if it was a full circle, would overlap with the E. This is not the case with the official CE mark. lol, go check your kitchen scale now  ;)
Anyway, I don't even need to touch a multimeter not to mention looking for certifications to figure out if its a $5 POS or something more decent. I also find high current measurements a good test for 'qualifying' quality as it puts a lot of stress on sensitive parts (PC traces, protection, shunt etc).
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #22 on: February 23, 2011, 03:44:05 pm »
i also have this dead cheapy dmm somewhere. for years i cant figure out the best way to make funeral for it, so i just keep it.
alm
  • Guest
« Reply #23 on: February 23, 2011, 03:55:50 pm »
Only if it falls under one of the new approach directives (which I believe includes DMMs), otherwise it's prohibited.
That means that the manufacturer/importer certifies that it's in compliance with whatever the requirements of the directive are, not that this was actually verified. They (distributor/importer/authorized representative/manufacturer, whoever has the deepest pockets) are probably liable if this turns out to be false, however.
Offline ziq8tsi
« Reply #24 on: February 23, 2011, 07:17:33 pm »
Haoyue/huayi, one of the big OEMs for these ultra-cheap manual ranging CoB meters, claim to be designing their new models in accordance with the CE requirements, rather than just sticking the logo on anyway:
  http://www.digimeter.com/views.asp?hw_id=377
The differences include removal of the transistor test socket, addition of a fuse on the 10A range, and the elimination of any suggestion of capabilities above 500V.
I suspect they are still made of flimsy brittle plastic and accompanied by probes that can pull off their cables exposing bare wire...
