Author Topic: EEVblog #707 - Rigol Oscilloscope Probe Performance  (Read 9010 times)
Online EEVblogTopic starter
« on: January 21, 2015, 10:36:31 pm »
This video is a response to a forum question that asks if the RP2200 150MHz probe supplied with the DS1054Z is degrading the performance of the scope compared with the 350MHz RP3300 supplied with the DS2000.
Are there any performance differences between the two probes on a 100MHz bandwidth DS1054Z?
The forum thread question: https://www.eevblog.com/forum/testgear/scope-probes-as-supplied-by-rigol-for-the-low-end-scopes-a-discussion/
Offline nixfu
Re: EEVblog #707 - Rigol Oscilloscope Probe Performance
« Reply #1 on: January 22, 2015, 02:26:33 am »
Wow.  Lots of those youtube commenters are dicks.
As someone who followed the original discussion here in the forum, and as a 1074Z owner, thanks for doing this quick video.
« Reply #2 on: January 22, 2015, 02:51:18 am »
Welcome to the world of youtube  ;D
Offline TMM
« Reply #3 on: January 22, 2015, 04:34:12 am »
Isn't the rise time of a DG4000 a bit marginal to be drawing conclusions between 150MHz and 350MHz probes?
Seems like something that needs to be taken into consideration because the actual bandwidth of a '100MHz' 1000Z is more like 150MHz.
Offline kjn4685
« Reply #4 on: January 22, 2015, 06:19:26 am »
I learned a lot from this video thanks Dave . There is another question I w like to ask you guys . This thing about scope probes I I had two probes one 60mhz and other 100 mhz. Which one would be the best. I ljust wanted say I appreciate you DAVE Jonrs and all the rest of you EE
Offline digital
« Reply #5 on: January 23, 2015, 08:16:46 am »
An excellent video Thank's Dave I learned a little bit more on the practical real world view.Regards to all
« Reply #6 on: January 23, 2015, 09:34:29 am »
No. As mentioned in the other thread, the idea was to confirm or deny the big differences between probes from the forum user, and the user used a timebase 10 times slower than I did. The rise time was 3ns.
Offline mxmarek
« Reply #7 on: January 24, 2015, 01:07:46 am »
wow, this video was quick, the magic smoke went off my brain ;)
« Reply #8 on: January 24, 2015, 07:29:04 am »
There is no noticeable difference between them up to about 50MHz, it will be the same response. The 100MHz one will work at 100MHz with a reduced response as per spec ( lower voltage than actual, but still in spec), but even the 60MHz one will still have a response at 100MHz. will be a lower voltage shown, and might show the waveform incorrectly as the higher frequency components are attenuated more, but it will still show something.
At DC and low frequencies there will be absolutely no visible difference.
Offline kjn4685
« Reply #9 on: January 24, 2015, 07:39:55 pm »
Thanks to everyone. I sure love this blog. There is so much information on here.
Offline petreza
« Reply #10 on: November 30, 2016, 07:53:19 pm »
In the youtube comments a user said what follows. Is that important?
HalfSpeedMastering1 year ago
1:11 the screenshot is 50ns = 20Mhz. ?
9:20 your screen shot is 200uS = 5KHz.?
