I get a smile on my face every time someone sends you a classic calculator!
You see, I collect calculators!
http://richfiles.solarbotics.net/calc/CalculatorShelf.jpghttp://richfiles.solarbotics.net/calc/DisplayCabinet.jpgI have over 100 calculators myself, including a 1965 Smith Corona Marchant (SCM) Cogito 240SR that
almost works (and by almost, I mean that it did work, but after moving, the keyboard register won't load into the working register anymore when you hit an operator key). That calculator is built up of discrete components, using resistor diode logic, and the absolute minimum number of transistors that RDL let them get away with. It uses a magnetostrictive delay line memory, a CRT display that outputs 4 LINES of numbers, and a solenoid locks the keyboard while it is in operation, because it's slow enough that stray keypresses would screw with it!
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
I have a Casio 121-A that does not yet work. It's a small scale integration based nixie calc, with a medium scale shift register memory. There is also my Friden EC-132... It is OLD... I think it too is around 1965. It's not quite in as working order as the Cogito. It uses a voltage doubler circuit to achieve the CRT voltages, and the indications are that that circuit is failing. The magnetostrictive delay line is also bordering on untuned. It SOMETIMES can perform a SMALL addition operation, but subtraction, division and multiplication tend to result in garbage. Larger numbers, most division operations, and EVERY attempt to perform a square root freezes the unit.
Still, there are many models I have that do work...
I've got a Remington 1259S. It's a small desktop scientific calculator that outputs using Nixie tubes... And the best part... It does NOT blank the display while calculating! Watching a cube root is a thing of BEAUTY! It's a regular neon numerical dance! It works
perfectly too! I also have a Canon Canola F-11 scientific calculator that also works, even if its not quite a cool as the old Remington!
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
I've also got a Monroe 344 Statistician, which looks like they re appropriated an early 70s cassette tape player housing (at least the dimensions) to build a "portable" programable statistics calculator!
Aside from the hoards of working machines, and the collection of non working ones I have as well, I've managed to successfully restore a couple calculators too. I restored a pair of Commodore N-60 Navigation calculators. Sold one to a pilot from Australia, and the other is sitting a foot from my hand, on my desk! A foot further down my desk is the Commodore S-61 I restored. I actually use these calculators regularly, and I love the huge "pocket sized" beasts! I've also got an HP-41CX that I did some VERY MINOR repairs to. I love the fact that HP included a piezo buzzer in this calculator! It's such a silly little thing, but it's simply not enough for it to be an AMAZING calculator. I mean, HP's engineers thought, we have this utterly amazing, programmable, expandable calculator... lets throw in a buzzer too just because! I guess so it can tell you audibly when it completes a program, or give you an audio cue for input, etc! Just thinking outside the box! Cool calc, HP!
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
I've also got an AMAZING HP 9825. This thing is called a calculator... It's full blown computer. 16 bit, 10 MHz CPU in 1976! Single line LED dot matrix display, a full QWERTY computer style keyboard, tape printer and tape drive, and expansion ports and cartridge slots EVERYWHERE!
Speaking of HP, now if ONLY I could find my dream machine, the HP 9100 (A or B)...
Why are you so impossible to find, 9100... And expensive!
![Cry :'(](https://www.eevblog.com/forum/Smileys/default/cry.gif)
I also can't find an early ANITA. They were nixie calculators with a full manual keyboard and neon filled thyratron tubes as switching elements. They used a dekatron or two for things like keyboard polling and such, and were the first electronic calc available to the public. I have 6 of the nixie decade counter pc boards and plan to build a custom calculator using telephone dials as inputs. Even finding those parts was a pain!
I also have fully restored a Sony SOBAX ICC-600W, by scavenging parts from a very ruined ICC-500W. These were nixie tube calculators, that had hybrid modules instead of integrated circuits. Hybrid modules were an interim between discrete components and chips, to any that are unfamiliar with them. generally, they were usually a ceramic plate with capacitors, diodes, transistors, etc bonded to a conductive trace on the plate. I think resistors were often carbon films right on the ceramic. They would then have leads attached to one end and were then potted. These were more common in the era when chips existed, but the military and aerospace industry was gobbling up anything they could get their hands on, and they were ridiculously expensive still. The finished SOBAX is BEAUTIFUL, works flawlessly, and since I had spare parts, I made a nixie tube clock to go in my 1939 Philco radio cabinet PC case!
http://richfiles.solarbotics.net/eb/NixieDetail.jpg http://richfiles.solarbotics.net/eb/PhilcoNixie.jpgAside from the Sony calculators, I also have an electronic organ that is PACKED with hybrid modules! I've wanted to take it apart, but I can't justify it... it's too amazing... The organ is packed with hybrid modules, has 18 plunger switches with 8 positions each. These are wired into a rats nest of enameled wires that lead off to a bank of boards that run the width of the entire dual manual (two keyboards) organ. Crazy amazing craftsmanship!
Finally, speaking of craftmanship, and rounding back to the topic of calculators, and more specifically, Russian calculators, I have an Elektronika MK 61. I can vouch for the cheapness of that plastic. OH MY!!! It HUUURTS my ears, and it feels WRONG!!! The cheapness! LOL
In all seriousness though, I love those old USSR models. The later stuff tends to universally feel cheap, like the death throws of the old USSR cut into their manufacturing ability or something. The earlier days had some amazing craftsmanship though! Furthermore, the technology, for better lack of a word, feels
alien. It took me a few minutes to realize a part inside one of my favorite Russian models was actually a FUSE HOLDER! I thought it was a pot!
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
The Soviets were truly cut off from the world because of the cold war. Their technological path diverges from the eastern and western paths. Often times, they flat out stole a western or eastern design. A LOT of their products were ripoffs of Japanese, European, and American tech, sometimes even going so far as to copy ROM content, board layouts, etc! Other times, they genuinely did their own engineering, but as a result of their isolation from the remainder of the world, their paths often diverged from our own... Familiar things... aren't! There is an almost anachronistic dichotomy between what they considered new vs what we considered old. I have a 1989 Elektronika MKy that has a case that draws it's styling from angular 1980's era design influences, uses asingle long VFD for it's display, not in a modern flat glass package, but a long "valve" style tube, with radial leads on one end, and the vacuum seal nipple on the other. It's primary chip was a staggered pin DIP, and it had an 8 pin DIP that was
not scaled to match our pin spacing... It was oversized. It also had a metal can IC. The case on that one actually felt rather solid, yet the keypad felt as cheap and as flimsy as the 1976 4-71b keypad! Heck! My Mky was shipped to me from the Ukraine in an ENVELOPE and survived!
http://richfiles.solarbotics.net/calc/Elektronika4_71b.jpgSince I mentioned it, I have an Elektronika 4-71b (or as best as an English keyboard can replicate Cyrillic text). Despite not being my best or most featured Soviet calc, it's my underdog favorite! This calculator looks like it went to war and came back... barely! It is MISSING parts of the case! It uses wonderful 9 segment displays and produces a lovely 1, 3, and 7 using said display! It's a simple 4 banger from 1976, nothing more. Inside are 4 staggered pin DIPs, and an EXQUISITE degree of workmanship! I suppose it should be expected from the land of the "worker". In Soviet Russia, all wire is hand lace by you! Seriously, the laced wire bundles are just...
pretty! I have to admit that I'd love to learn that hand laced wire bundle technique. It really adds something special to any project, and it's a PURE JOY anytime I encounter the technique in any vintage electronic device!
Now if only I could track the problem in my Cogito down! Sadly, I have no schematics for it... So no idea where to start.
